port down
vishalpatil86
I have a 2960 switch to which printer is connected
port configuration is -
#show run innt fa0/2
interface fastethernet 0/2
switchport access vlan 20
Problem is, after some time, that port goes down and i have to restart the switch.
But, when i connect the printer indirectly to the switch i.e. putting small d-link switch(8 port), it works just like normal
I tried everything hysically. Am i missing anything in switch configuration.
Please help
8 Replies 8
John Blakley
The port shuts down or is it err-disable? How often does it happen? The port looks pretty basic, and for a printer it shouldn't need to be configured special. The next time it happens, can you post:
sh int fa0/2
HTH, John *** Please rate all useful posts ***
Jan Hrnko
Level 4
Level 4
Hi Vishal,
Can you also post:
show port-security interface fa0/2
Thank you.
Best regards,
Jan
sure....
hi,
I observed one more thing...
Same printer is attched to the switch to different port. That port is working fine,,,,,
please find attached port config for these two ports
You most likely have a cable issue.  The best bet is to run a TDR, which the 2960 "kinda" support.
hi,
I think I got the problem; the port went to err-disabled mode
sw#sh int fa0/3
FastEthernet0/3 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 0024.f98d.8d83 (bia 0024.f98d.8d83)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 20:38:36, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     21132 packets input, 1353478 bytes, 0 no buffer
     Received 303 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     675919 packets output, 51816930 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Now I dont understand that why it is in err disabled mode...
Please suggest..
Can you check "show log" for the reason of  port being error-disabled.
Nik
HTH,
Niko
Kindly post the output to the command "sh interface f0/3 status err".
