Port Spanning Configuration Question
ckozub015
This is probably far too basic a question, but I having a hard time finding an answer.  Can you configure a spanning session from a lesser speed interface to a greater speed interface?  We have two 6509's configured with VSS in our DC and there are 10Gb fiber interfaces which connect to HP Flex-10 switches that are in our blade chassis.  Our server guy wants to do a packet capture of that traffic, but needs to run it from his laptop which would connect via a 1Gb copper interface on the 6509.  Is this possible?  Is there an easier way to do this?  Any help would be greatly appreciated.
Thanks.
Chris
Nagaraja Thanthry
Conceptually, it is possible to configure the port spanning the way you have
described. However, the results may not be as you would have expected. If
the traffic passing through that interface is beyond a Gig per second, then
you may not see everything on your destination port. Other than that, it
should work fine.
NT
Edison Ortiz
Yes, it's possible.
You may have packet drops if the aggegate speed of all SPAN source ports is greater than the SPAN destination port but it's definitely doable.
Edison
Here is a link that should help you as well.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Please remember to rate any posts that help.
Mike
Great info +5 for those posts
