Portchannel question
grapevine
We have 3 Cisco IE-9320 in a stack. We have a Portchannel connecting to ESXI from switch 2 port 3 and switch 3 port 4
4 Po4(SU) - Gi2/0/3(P) Gi3/0/4(P).
Ports are in bundled.
GigabitEthernet2/0/3 media type is 10/100/1000BaseTX SFP
GigabitEthernet3/0/4  media type is 10/100/1000BaseTX
ESXI nic teaming is configured as Route based on IP hash.
Ping to esxi is dropping intermittently
SW01#sh run int Po4
Building configuration...
Current configuration : 127 bytes
interface Port-channel4
switchport trunk allowed vlan 16,18
switchport mode trunk
end
SW01#sh run int Gi2/0/3
Current configuration : 168 bytes
interface GigabitEthernet2/0/3
channel-group 4 mode on
end
SW01#sh run int Gi3/0/4
interface GigabitEthernet3/0/4
end
arp is incomplete for esxi in firewalls. please advise how to fix it
24 Replies 24
monitor capture PO type traffic interface Port-channel1 both
monitor capture PO match ipv4 host <EXSI host IP> any
monitor capture PO start <<- start ping to ESXI one for host in vlan16 and other in vlan 18
monitor capture PO stop
show monitor capture PO brief
share the output of brief
MHM
PVW-CSW01#show monitor capture po parameter
monitor capture po interface Port-channel4 BOTH
monitor capture po match ipv4 any host 10.150.16.43
monitor capture po buffer size 10
monitor capture po limit pps 1000
PVW-CSW01#show monitor capture po ?
buffer Display captured buffer
parameter Display commands used to create capture point
| Output modifiers
<cr> <cr>
PVW-CSW01#show monitor capture po buffer
buffer size (KB) : 10240
buffer used (KB) : 0
packets in buf : 0
packets dropped : 0
packets per sec : 0
did you  start ping then stop the capture ?
PVW-CSW01#show monitor capture po buffer brief <<-
Yes I started and stopped
PVW-CSW01#monitor capture po start
Started capture point : po
PVW-CSW01#ping 10.150.16.43
Sending 5, 100-byte ICMP Echos to 10.150.16.43, timeout is 2 seconds:
Success rate is 0 percent (0/5)
PVW-CSW01#monitor capture po stop
Bytes dropped in asic - 0
Stopped capture point : po
packets in buf : 0
packets dropped : 0
packets per sec : 0
PVW-CSW01#show monitor capture po buffer ?
brief brief display
detailed detailed disaply
dump for dump
| Output modifiers
<cr> <cr>
# size timestamp source destination dscp protocol
10.150.16.43 <<- this IP in VLAN16 ? if Yes try IP in VLAN18
MHM
I shut and enabled the portchannel and I see this
C:\Users\abc>ping 10.150.16.43 -t
Pinging 10.150.16.43 with 32 bytes of data:
Reply from 10.150.16.43: bytes=32 time=92ms TTL=58
Request timed out.
Reply from 10.150.16.43: bytes=32 time=94ms TTL=58
Request timed out.
Reply from 10.150.16.43: bytes=32 time=93ms TTL=58
Request timed out.
Ping statistics for 10.150.16.43:
Packets: Sent = 10, Received = 7, Lost = 3 (30% loss),
Approximate round trip times in milli-seconds:
Minimum = 92ms, Maximum = 94ms, Average = 92ms
do capture and check
if you see traffic in both way
then this cons of using ON mode of PO, you need to force shut/no shut PO to make it work
MHM
before run capture
try shut/no shut PO since you run ON mode and one of stack SW is down 21 hrs ago
MHM
grapevine
We powered off switch one by one in the stack, then noticed if the ESXI was reachable. the issue was that once the switch got added to the stack, the ESXI went unreachable
We figured out the issue. We issued the command spanning-tree portfast trunk on the portchannel and the issue resolved
We also had an issue with SFP that connected to ESXI2, we replaced it and it resolved.
Thank you all for the support
I am 1000% sure issue appear again'
With mode ON you need always to check PO.
Update me if it appear
MHM
