priority-queue out command
tedauction
Level 5
Level 5
Hello, can you put the command 'priority-queue out' command on a trunk interface or is this only for layer 3 interfaces ?
Thank you.
Mark Malone
You would only use that on an access port layer 2 where a phone/pc is connected not on a trunk or layer 3 interface
it basically services the priority queue in qos before any other queue , be careful using this it can cause starvation for the other queues in mls qos when in place , you get 4 queues 1 p and 3 srr or wrr , the p queue when there's packets in it will be used first to ensure no delay in critical traffic like voice
Hello guys, thanks for your replies however they seem contradictory.
Can someone please clarify if it is valid/common to use this command on a L2 trunk interface ?
My consideration is that if the trunk between two switches is bottlenecking, then perhaps this command would expedite EF marked traffic via 'priority-queue out'.
Thank you kindly.
Unable to comment how "common" this is, especially as QoS isn't as common as it probably should be.
However, here's an interface config from an active 3560:
xxx#sh run in g0/1
Building configuration...
Current configuration : 247 bytes
interface GigabitEthernet0/1
 description PHY|1G|TRUNK|rhost:xxx|rport:ge0/1
 switchport mode trunk
 srr-queue bandwidth share 25 5 25 70
 priority-queue out
 mls qos trust dscp
end
PQ is enabled to support DSCP EF.
Joseph W. Doherty
It should support any interface, trunk, L3 or L2.
