Problem after switch 2960x update
saeed205@protonmail.com
Community Member
Hello
I have a 2960x switches that on 4 of these switches after the IOS update to the latest version (15.2(7)E4) of Cisco gives the following error, I do not even work with the previous version
Jun 27 16:37:16: %ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization.  This product may contain software that was copied in violation of Cisco's license terms.  If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet.  Please contact Cisco's Technical Assistance Center for more information.
We do not use STACK :
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63972.html
Thanks for pointing out why this is happening and how to fix it
balaji.bandi
physically powering off device for 15 minutes and  Power on and test it - some users have success.
there are some bug reported : check below troubleshoot :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2960-x-series-switches/118837-technote-catalyst-00.html
sitll issue raise an TAC case to support you.
BB
Leo Laohoo
This is a known issue with the 2960X and the only fix is to RMA the appliance.
Mohsin Alam
++ Remove stack modules if you have
++ Hard power cycle
++ If in stack remove all switches and check individual switches
++ Nothing works --> RMA
## Make sure to mark post as helpful, If it resolved your issue. ##
