Problem with 2960S switch, can't get rid of "shutdown" command
bill.roland
Hi everyone.  I am having a problem that I cannot figure out.  I tried to bounce a couple of ports by issuing the following command:
int gi1/0/20
shut
no shut
The interface now shows as Administratively down.  When I do a show run, I still see the "shutdown" command on the interface.  I can issue "no shut" 6 ways to Sunday, but the command won't clear and the port won't come up.
Any suggestions?  I've done this dozens of times and never had something like this happen.
Thanks in advance.
POST: Inline Power Controller Tests : Begin
POST: inline power post failed for port 16
POST: inline power post failed for port 17
POST: inline power post failed for port 18
POST: inline power post failed for port 19
POST: Inline Power Controller Tests : End, Status Failed
Gotcha!  No wonder.
Please contact Cisco and organize to get the appliance replaced.  It's dead-as-a-doornail.
12 Replies 12
Somasundaram Jayaraman
Can you make the interface as default interface and put the configurations one by one and check.
The shutdown command stays in the running config of the interface thats why.
To make interface default,
conf t
default interface gig 1/0/20
no shut
exit.
Hope this helps
Cheers
Somu
Rate helpful posts
Hi Somu.  This is what I get when I issue the command per your post:
2960s_48po(config)#default int gi1/0/20
% Error(s) seen setting interface GigabitEthernet1/0/20 to it's default config
2960s_48po(config)#
Anyway to find out what Errors it saw?
Something doesn't look right with this.  Can you post the following command outputs please:
1.  sh version
2.  sh switch status
Hi, here is what you asked for:
1.
2960s_48poe#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE2,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 11-Jan-11 02:23 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWA
RE (fc3)
2960s_48poe uptime is 2 hours, 31 minutes
System restarted at 19:25:49 EDT Fri Aug 12 2011
System image file is "flash:/c2960s-universalk9-mz.122-55.SE2/c2960s-universalk9
-mz.122-55.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision C0) with 131072K bytes of
memory.
Processor board ID FOC1516Y3H9
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E8:BA:70:04:BC:00
Motherboard assembly number     : 73-11907-06
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC15155DBX
Power supply serial number      : DCA1512U0AC
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48LPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC15153PZ9
System serial number            : FOC1516Y3H9
Top Assembly Part Number        : 800-30937-02
Top Assembly Revision Number    : B0
Version ID                      : V02
CLEI Code Number                : COMGZ00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48LPS-L  12.2(55)SE2           C2960S-UNIVERSALK9-M
Configuration register is 0xF
2.
2960s_48poe#show switch status
% Invalid input detected at '^' marker.
This is bizarre!
Can you post the command output of "sh post" please?
2960s_48poe#show post
Stored system POST messages:
Switch 1
POST: MA BIST : Begin
  FC 1   MBIST Test Passed.
  DP Sg1 MBIST Test Passed.
  DP Xg1 MBIST Test Passed.
  NI 1   MBIST Test Passed.
  FC 0   MBIST Test Passed.
  DP Sg0 MBIST Test Passed.
  DP Xg0 MBIST Test Passed.
  NI 0   MBIST Test Passed.
  UPB    MBIST Test Passed.
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Gotcha!  No wonder.
Yeah, as soon as I saw that I knew I was SOL  Thanks for looking over things everybody, I'll give TAC a shout and take it from there.
Hi Bill,
Thanks for the rating.
Cisco Limited Lifetime Hardware Warranty
Cisco Catalyst 2960-S and 2960 Series Switches come with a limited lifetime warranty (Table 11). The warranty for the Catalyst 2960-S has the same terms as our standard limited lifetime warranty plus the addition of next business day delivery of replacement hardware where available and 90 days of 8X5 Cisco Technical Assistance Center (TAC) support.
Your formal warranty statement, including the warranty applicable to Cisco software, appears in the Cisco information packet that accompanies your Cisco product. We encourage you to review carefully the warranty statement shipped with your specific product before use.
Cisco reserves the right to refund the purchase price as its exclusive warranty remedy.
I too have this problem. First I am seeking to upgrade the IOS to a higher version. Or still retain the same version but replace the one that gives this error..If this is a hardware problem, I wonder how all the ports just died by themselves and not other components... So please try replacing the IOS and see..I shall give my feedback after the IOS replacement goes through successfully.
Leo Laohoo
Maybe it's in "error-disable"?
ayongpalapa
We just repair CISCO WS-2960S-F48LPS-L V01 from customer, 3 units with POST error : Inline power post failed on port XX / can't be brought up because it failed POST in Inline Power test.
The error comes up during Cisco power on self test (POST) on POE loopback test in each port. When a port or some have problem, it will report error and shutdown / disable the port or whole ports of the interface.
We have successfully fix the POE module and power controller on the mainboard.
Cheers from Jakarta, Indonesia. ayong palapa
