Problem with 9200 and 9500 truking with SFP+ (10G-LR)
chpaul13
I configured a link trunk between a 9200 and a 9500 with SFP+ (SFP-10GBase-LR)
but it does not work. the 9200 sees the 9500, the 9500 does not see the 9200 (with "show cdp neighbors"). On the 9500, 0 packets input...
When I test with an rj45 port, it works.
With the same 9500 I have no problem with 9200L...
Thanks for your help !
14 Replies 14
balaji.bandi
is the port come up, can you post show run interface x/x and show interface x/x (from both the sides)
what Mode of cable you using, how far distance between Cat 9200 and Cat 9500
BB
Check ports on 9500 SFP connect with the supported 10G port..
The Cisco Catalyst 9500 Series Switches family consists of fixed core and aggregation layer switches supporting redundant power supplies and modular fans. The Cisco Catalyst 9500 Series offers switch models with downlink ports of the following types:
  • 8 ports of 400G QSFP-DD
  • 16, 28 and 32 ports of 100G QSFP28
  • 12, 24 and 32 ports of 40G QSFP
  • 24 and 48 ports of 25G SFP28
  • 16, 24, 40 and 48 ports of 10G SFP/SFP28
Below is the both switch hardware installation guide..
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/hardware/install/b_catalyst_9500_hig/b_catalyst_9500_hig_chapter_01001.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/m_9300_installing_a_network_module.html#topic_6C2E7F93C4D4472ABF9766C84E75636C
Jitendra
check id CDP disabled on 9200 connected port.
Good luck
KB
Leo Laohoo
  1. What firmware are the switches on?
  2. What are their uptimes?
1. for 9200 : Version 17.03.04 and for 9500 : Version 17.3.1r[FC2], RELEASE SOFTWARE (P)
2. ???? I do not understand the question (sorry, i'm french...)
chpaul13
For all, I've already changed all Gbic, fiber, I put the two switch side by side with just a garter between them. I also tested with a DAC cable.
The strangest thing is that on the 9500 there is "0 paquets input"
Leo Laohoo
Post the complete output to the command "sh version" from both switches.
There is an uptime bug that occurs with the 9500 where it would cause the SFP ports to randomly stop passing traffic.
9200 :
Cisco IOS XE Software, Version 17.03.04
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Fri 02-Jul-21 19:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.5.1r [FC4], RELEASE SOFTWARE (P)
AudioVisuel-Rep4 uptime is 23 hours, 4 minutes
Uptime for this control processor is 23 hours, 6 minutes
System returned to ROM by Power Failure or Unknown
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9200-48P (ARM64) processor with 651499K/3071K bytes of memory.
Processor board ID JAE25400YEJ
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4028872K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
Base Ethernet MAC Address : c4:4d:84:5c:04:80
Motherboard Assembly Number : 73-20259-03
Motherboard Serial Number : JAE25400YEJ
Model Revision Number : C0
Motherboard Revision Number : A0
Model Number : C9200-48P
System Serial Number : JAE25400YEJ
CLEI Code Number : INM9200ERB
Switch Ports Model SW Version SW Image Mode
* 1 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
Configuration register is 0x102
9500 :
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Compiled Sat 03-Jul-21 01:55 by mcpre
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.3.1r[FC2], RELEASE SOFTWARE (P)
AudioVisuel_Fibre uptime is 1 week, 23 hours, 11 minutes
Uptime for this control processor is 1 week, 23 hours, 13 minutes
System returned to ROM by PowerOn
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
export@cisco.com.
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
cisco C9500-48Y4C (X86) processor with 2904230K/6147K bytes of memory.
Processor board ID FDO25500F3Z
48 TwentyFive Gigabit Ethernet interfaces
4 Hundred Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16002876K bytes of physical memory.
11161600K bytes of Bootflash at bootflash:.
1638400K bytes of Crash Files at crashinfo:.
Base Ethernet MAC Address : 38:fd:f8:ff:48:60
Motherboard Assembly Number : 4873
Motherboard Serial Number : FDO25500F3Z
Model Revision Number : V02
Motherboard Revision Number : 5
Model Number : C9500-48Y4C
System Serial Number : FDO25500F3Z
  1. Are both ends using LR optics?
  2. Are both ends using single mode OS2 patch cables?
  3. What is the distance between the two optics?
for me the problem doesn't come from there, because I installed the two equipments side by side, I put a direct DAC cable and there is the same problem...
What is the exact model of the DAC cable and where is the DAC head-end installed, on the 9500?
chpaul13
I just did some more testing and I still have the same problem.
the 9200 receives and sends packets, on the other hand the 9500 receives but does not send packets.
Thank you...
Can you post from both device interface config :
show interface x/x
show logg
BB
