problem with automatic archive
vlad09
I have configured automatitic archivation of running config via archive command to TFTP server. I have done the same configuration on 8 switches, but 4 of them doesnt archive config properly, they archive "blank" cfg 1kB of size. If I use write command, config is archived and sent to the TFTP server properly.
Any ideas?
you might be hitting the bug below. Try and upgrade to one the fixed versions:
Archive feature saves blank config
CSCtf51974
Description
Symptom:
Blank configuration file is created when trying to archive running configuration.
Conditions:
Schedule backup always kicks off at archive schedule time but a blank config is copied to ftp server.
- if a change is made to config full archive of config occurs
- manual archive always saves full config to ftp server
Affects 3560s/3750s.
- Always kicks of at schedule time but blank config archived
- manual archive saves full config
- config change and auto archive will save full config
Workaround:
None.
Known Fixed Releases: (356)
15.2(2)E
15.2(1)EY
15.0(2)SE6
15.0(2)SE5
15.0(2)SE4
15.0(2)SE2
15.0(2)SE1
15.0(2)SE
15.0(2)EY2
5 Replies 5
balaji.bandi
what kind of device is this, what IOs running ?
BB
for example:
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960-24PC-L    12.2(50)SE5           C2960-LANBASEK9-M
CSCtf51974
Description
Symptom:
Conditions:
Workaround:
None.
15.2(2)E
15.2(1)EY
15.0(2)SE6
15.0(2)SE5
15.0(2)SE4
15.0(2)SE2
15.0(2)SE1
15.0(2)SE
15.0(2)EY2
Thank you, 100% its a bug in iOS, now I checked my working switches and they are running at newer version than the affected ones.
I will upgrade
