Problem with etherchanel please help
Edil Cajigas
Community Member
I was previously using two 4507 switches with the same IOS and same supervisor modules [dual WS-X4515 SUPERVISOR ENGINE IV]. An etherchannel was setup and running without problems. Switch #1 got damaged and had to be replaced with a new 4507 with new supervisor modules [dual WS-X45-SUP7L-E]. The IOS in the new switch1 is newer than the IOS of the older switch2.
After the entire configuration was in place I tried to establish the etherchannel but it doesn't want to go up in the new switch1, it does shows up in the old switch2. I want to use the default vlan1 and the interfeaces are in access mode, not trunk. Both switches can ping each other, but the status of the etherchannel on the new switch1 is listed as down. I tried all the modes for the etherchannel; active, auto, desirable, passive but none of them work, each and every time I removed the port-channel interface and start from scratch. I tried to force speed and duplex but it get worse, also with and without spanning-tree portfast. Anyways the setup with the old switch was running with the “ON” mode and the interfaces on their default speed and duplex setting and that's the way I prefer to run the configuration. Interfaces on both switches have the same capacities. I issued the [DEBUG ETHERCHANELL ALL] command on the new switch1 but no information gets displayed on the console.
Can you please provide some help?
[SWITCH1 IOS]
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.02.SG RELEASE SOFTWARE (fc1)
ROM: 15.0(1r)SG10
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Module Name        Role    Current Level    Reboot Level
WS-X45-SUP7L-E    Active    ipbase            ipbase
                Standby    ipbase            ipbase
[SWITCH1 ETHERNET PORT MODULES]
"Linecard(slot 6)", DESCR: "10/100/1000BaseT (RJ45)+V E Series with 48 10/100/1000 baseT Premium PoE ports (Cisco/IEEE)"
PID: WS-X4748-RJ45V+E  , VID: V03  , SN: CAT1749L7UX
[SWITCH 1 ETHERCHANNEL CONFIGURATION]
    interface Port-channel1
     switchport
     switchport mode access
    interface GigabitEthernet6/47
     description Etherchannel to SWITCH2
     channel-group 1 mode on
    interface GigabitEthernet6/48
[SWITCH1 ETHERCHANNEL STATUS & SUMMARY]
    GigabitEthernet6/47    unassigned    YES    unset    down    down
    GigabitEthernet6/48    unassigned    YES    unset    down    down
    Port-channel1        unassigned    YES    unset    down    down
    Number of channel-groups in use: 1
    Number of aggregators:           1
    Group  Port-channel  Protocol    Ports
    1      Po1(SD)          -        Gi6/47(D)   Gi6/48(D)
[SWITCH2]
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA11, RELEASE SOFTWARE(fc1)
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 32
MPC8245 CPU at 333Mhz, Supervisor IV
cat4000-i9s-mz.122-25.EWA11.bin
[SWITCH2 ETHERNET PORT MODULE]
    "Linecard(slot 4)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 baseT ports"
    PID: WS-X4548-GB-RJ45  , VID: V05, SN: JAE11430WKZ
[SWITCH2 ETHERCHANNEL CONFIGURATION]
     switchport
    interface GigabitEthernet4/47
     description Etherchannel to SWITCH1
    interface GigabitEthernet4/48
[SWITCH2 ETHERCHANNEL STATUS & SUMMARY]
GigabitEthernet4/47    unassigned    YES    unset    up    up
GigabitEthernet4/48    unassigned    YES    unset    up    up
Port-channel1        unassigned    YES    unset    up    up
    1      Po1(SU)          -        Gi4/47(P)   Gi4/48(P)
More detailed information:
SWITCH1#sh etherchannel 1 detail
Group state = L2
Ports: 2   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
Ports in the group:
Port: Gi6/47
Port state    = Down Not-in-Bndl
Channel group = 1           Mode = On              Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 0d:03h:35m:37s
Port: Gi6/48
Age of the port in the current state: 0d:03h:35m:33s
Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 0d:03h:36m:21s
Logical slot/port   = 21/1          Number of ports = 0
GC                  = 0x00000000
Port state          = Port-channel Ag-Not-Inuse
Protocol            =    -
Port security       = Disabled
SWITCH2#sh etherchannel 1 detail
Group state = L2
Protocol:    -
Ports in the group:
Port: Gi4/47
Port state    = Up Mstr In-Bndl
Channel group = 1           Mode = On/FEC          Gcchange = -
Port-channel  = Po1         GC   =   -             Pseudo port-channel = Po1
Age of the port in the current state: 00d:03h:40m:02s
Port: Gi4/48
Port index    = 1           Load = 0x00            Protocol =    -
Age of the port in the current state: 00d:03h:39m:56s
Port-channel: Po1
Age of the Port-channel   = 04d:06h:28m:30s
Logical slot/port   = 11/1          Number of ports = 2
GC                  = 0x00000000
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi4/47   On/FEC             0
  1     00     Gi4/48   On/FEC             0
Time since last port bundled:    00d:03h:39m:57s    Gi4/48
Edil Cajigas
Community Member
Ok, fixed moving to different ports and recreating the port-channel with different number.
Thanks.
Glad you got it fixed and thanks for posting back.
Just one thing, please don't use portfast on the link between the switches as any version of portfast should not be used for switch interconnections.
Jon
