problem with etherchannel between 3750 and IBM ESXi 5.0
teymur azimov
Hi Dear,
I configurated cisco catalyst switch 3750 as stack and then i configurated etherchannel between ESXi 5.0.
this is my etherchannel config:
interface Port-channel1
switchport mode trunk
switchport nonegotiate
interface Port-channel2
interface GigabitEthernet1/0/6
description ESX01 Management (on-board)
channel-group 1 mode on
interface GigabitEthernet2/0/6
interface GigabitEthernet1/0/5
channel-group 2 mode on
interface GigabitEthernet2/0/5
Switch#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
        src-dst-ip
when i wrote show etherchannel summary
it show me all of them are ok. SU and P.
the ping is sometimes is going and sometimes is not.
what is a problem?
i changed mode active, passive the but
the etherchannell is not connected.(down)
please help me. thanks.
Reza Sharifi
Under po1 and 2 do a sh and no sh
than
Can you post "sh etherch summ"?
can you post "sh ether deta"?
Is the SXI server configured as po also?
adamorodrigues
Hi - use "channel-group 2 mode active" to enable LACP.   On the ESX configure it as "route based by origional source IP"
Works for us
mahmoodmkl
Level 7
Level 7
I suggest you use LACP as the channel protocol for u r ether channels.
I see it is missing in u r config.
