Bookmark
Subscribe
1532
problem WS-C6509-E with sup720-3BXL - Software-forced reload
I installed a new WS-C6509-E and shortly after was in Software-forced reload.
The message is:
%Software-forced reload
15:19:28 UTC Wed Sep 21 2011: Breakpoint exception, CPU signal 23, PC = 0x425CEFF8
   Possible software fault. Upon reccurence, please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
ecc..
I replaced the SUP, the IOS, removed all modules interfaces and I have used two different power supplies. But the problem continues.
Has anyone had the same problem and knows how to solve?
Cristian
5 Replies 5
Somasundaram Jayaraman
Could you please share the crash info file for analysis.. It may be in bootflash, sup-bootflash.
To view the crashinfo file, more bootflash:, more sup-bootflash:
Somu
Leo Laohoo
Based on the amount of information you have provided, I can accurately say it's a software-caused crashed.
Hi all,
The problem was solved.
Maybe it was the ground.
greetingsThe problem was solved.
greetings.
Do you remember how to fixed this issue?
thanks a lot
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Leo Laohoo
