Problems Gibc 10Gb with Switch cisco 4503
Alexandre11
Cliente tem problemas ao ligar uma fibra com GBICs de 10GB entre um switch cisco WS-C4503-E ao um switch dell modelo S4128F-0N no switch cisco a fibra é conectada no modulo WS-X45-SUP7L-E esse módulo tem com 4 portas SFP.
Cliente testou testou na primeira interface ele mostra como Gi1/3 nos logs e depois conectou um cabo de stack modelo(053HVNLS65F018-SD-R) ele mostra como Gi1/4 nos logs abaixo:
as interfaces não sobem.
000714: Jun 19 2020 09:22:24.541 BR: %GBIC_SECURITY-4-UNSUPPORTED_GBIC_INSERTED: Unsupported transceiver inserted in port Gi1/4
000715: Jun 19 2020 09:22:24.541 BR: %C4K_CHASSIS-3-TRANSCEIVERCRCINTEGRITYCHECKFAILED: Transceiver integrity check on port Gi1/4 failed: bad crc
000716: Jun 19 2020 09:22:24.566 BR: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=4: Transceiver has been inserted
000717: Jun 19 2020 09:22:27.224 BR: %GBIC_SECURITY-4-UNSUPPORTED_GBIC_INSERTED: Unsupported transceiver inserted in port Gi1/3
000718: Jun 19 2020 09:22:27.224 BR: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/3: New transceiver (speed 10Gbps) is incompatible with this module
000719: Jun 19 2020 09:22:27.224 BR: %C4K_CHASSIS-3-TRANSCEIVERCRCINTEGRITYCHECKFAILED: Transceiver integrity check on port Gi1/3 failed: bad crc
GBIC MODELO: SFP-10GB-10LR Marca: Dell
cabo de stack modelo (053HVNLS65F018-SD-R)
17 Replies 17
Solved the problem, after we entered the command hw-module uplink select tenethernet and saved the configuration.
Port Name Status Vlan Duplex Speed Type
Te1 / 1 CASCATA notconnect 1 full auto 1000-DWDM-54.94- *
Te1 / 2 CASCATA connected trunk full 10G 10GBase-LR- *
Glad all working as expected - and nice to hear back your feedback.
BB
Hello @Alexandre11 ,
good news you have solved
This influences only the ports of the supervisor in slot1 it has not effects on linecard on slot 2.
Hope to help
Giuseppe
