Pruning
vu2jjq
Community Member
I am using vlan 13 as my native vlan with dot1q trunking. I have enabled VTP pruning.
When I see the show interface trunk command, even the native vlan 13 is pruned. Is there any implication on the functionality in such case? How can I make a vlan non-prunable?
TIA
8 Replies 8
hi,
so no vlan traffic is passing the link?
kamal-learn
Level 7
Level 7
hi
VTP pruning does not prune traffic from VLANs that are pruning-ineligible such as native vlan always 1 unless you change it.
i think you enabled pruning before changing the native vlan, undo your work and change the native first and enable pruning second.
and let us know
Native vlan is set on vlan 13, before enable pruning. But all I see is the following:-
Port Mode Encapsulation Status Native vlan
Gi3/8 on 802.1q trunking 13
Port Vlans allowed on trunk
Gi3/8 1-4094
Port Vlans allowed and active in management domain
Gi3/8 1,13,15,20-21,25,30,35,40,45,50,55,60,65,70,75,80,85,90,100,105,500
Port Vlans in spanning tree forwarding state and not pruned
Gi3/8 1,30,40
The following is the interface config:
switchport
switchport trunk native vlan 13
switchport mode trunk
Again my question is how to forward vlan 13 and not to be pruned.
hi,
Is spanning tree blocking this link?
Are you using per vlan spanntree?
regards
J.
PVST is being used.
There is only a single uplink to this switch to the downstream one. It is not in blocked state.
JJQ
Can you post the sh trunk on both sides. Or sh int gig X/x trunk, sh int gig x/x switchport
thanks
J
Please explain your network connectivity. I believe that you have not manually taken the vlan 13 from the trunk interface of the other switch.
Do you have any PC connected in vlan 13 on this switch?If you dont have any PC in this switch this vlan will be pruned on the trunk interface. This is how VTP pruning work. If you have even a single host in the vlan 13on this switch the vlan will be in STP forwarding and non-pruned state.
HTH,
-amit singh
From the Dist Switch:-
LAW-SOCSCI#sh int gi 3/8 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 13 (Native_VLAN_for_dot1q)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Voice VLAN: none (Inactive)
Appliance trust: none
From the Edge Switch
SS-G-FF-3550-24PWR-6#sh int gi 0/1 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
