PTP interface status is not changing from uncalibrated to SLAVE state
I was trying to PTP sync across our research network, but at one point, one device's PTP interface stuck at UNCALIBRATED mode, instead of changing to SLAVE mode. Both Master and Slave devices are Cisco 9300 and they are connected using fiber. But it's down stream device's (9300) port status also changed to slave mode. Would you please help me to resolve this issue?
TwentyFiveGigE1/1/1 24 UNCALIBRATED
5 Replies 5
balaji.bandi
what IOS XE Code running, how is your network hierarchy looks like, it show domain 24  is that matches in the config of others ?
check below reference guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-12/configuration_guide/lyr2/b_1612_lyr2_9300_cg/configuring_precision_time_protocol__ptp_.html
UNCALIBRATED  - is part of election process - how is your configuration looks like ?
check troubleshooting :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/221062-troubleshoot-precision-time-protocol-pt.html
BB
Thanks Balaji for your reply.
So, in our case,
Grandmaster clock directly connected to the 1st Cisco 9300 with ethernet cables.(tenG 1/0/4, already this interface SLAVE MODE, and already PTP synced)
TenGigabitEthernet1/0/4 24 SLAVE (to GMC)
TwentyFiveGigE1/1/1 24 MASTER (to 2nd Sw)
1-Mgmt-sw-9300#sh ptp parent
PTP PARENT PROPERTIES
Parent Clock:
Parent Clock Identity: 0x84:C8:7:FF:FE:5F:7E:40
Parent Port Number: 2
Observed Parent Offset (log variance): 17258
Observed Parent Clock Phase Change Rate: N/A
Grandmaster Clock:
Grandmaster Clock Identity: 0x84:C8:7:FF:FE:5F:7E:40
Grandmaster Clock Quality:
Class: 6
Accuracy: Within 100ns
Offset (log variance): 20061
Priority1: 128
Priority2: 118
1-Mgmt-sw-9300#show platform software fed switch active ptp domain
Displaying data for domain number 24
Profile Type : DEFAULT
Profile State: enabled
Clock Mode : BOUNDARY CLOCK
Delay Mechanism: : END-TO-END
PTP clock : 2024-5-26 16:19:15
mean_path_delay 86 nanoseconds
Transport Method : 802.3
Message general ip dscp : 59
Message event ip dscp : 59
1st Cisco is connected with fiber to 2nd Cisco 9300 (twenG 1/1/1, interface mode UNCALIBRATED)
2-9300-new#sh ptp br | inc TwentyFiveGigE
TwentyFiveGigE1/1/1 24 UNCALIBRATED (to 1st sw)
TwentyFiveGigE1/1/2 24 MASTER
TwentyFiveGigE1/1/3 24 MASTER
TwentyFiveGigE1/1/4 24 MASTER
TwentyFiveGigE1/1/5 24 MASTER (to 3rd sw)
2-Mgmt-9300-new#sh ptp parent
Parent Clock:
Parent Clock Identity: 0x64:8F:3E:FF:FE:B2:14:0
Parent Port Number: 57
Grandmaster Clock:
Class: 6
Priority1: 128
Priority2: 118
2-Mgmt-9300-new#show platform software fed switch active ptp domain
PTP clock : 1970-1-2 15:15:44
mean_path_delay 0 nanoseconds
Message general ip dscp : 47
2nd Cisco is connected with fiber to 3rd Cisco 9300 (twenG 1/1/1, interface mode already SLAVE mode)
3-Sw-9300#sh ptp brief | inc TwentyFiveGigE1/1/1
TwentyFiveGigE1/1/1 24 SLAVE
3-Sw-9300#sh ptp parent
Parent Clock:
Parent Clock Identity: 0x4C:EC:F:FF:FE:B:64:0
Parent Port Number: 61
Grandmaster Clock:
Class: 6
Priority1: 128
Priority2: 118
3-Sw-9300#show platform software fed switch active ptp domain
PTP clock : 1970-1-2 15:12:42
mean_path_delay 9254 nanoseconds
Message event ip dscp : 47
I recently encountered this bug on various platforms (IE-9300, IE-4000, IE-5000); the problem was that:
* Cisco IOS sends the multicast Layer3 PTP [ DELAY_REQ ] packets towards the PTP grandmaster with a source IP address of [ 0.0.0.0 ]
* The PTP Grandmaster, HOPF 8100, discards the [ DELAY_REQ ] and does not respond with a [ DELAY_RESP ]
The following diagram and command output of "show ptp () counters messages" (Adjust the syntax for Cisco IOS-XE) illustrates the problem.  Let us know if your DELAY_REQ is incrementing but your DELAY_RESP is remaining at zero (0).
Then you have the same bug we found.
The work-around we implemented: Create an SVI/BVI/VLAN interface in the same VLAN with an IP in the subnet matching/corresponding as the access switchport VLAN corresponding to the port facing the PTP GM.
YOU MAY EVEN SHUTDOWN THAT VLAN INTERFACE.
The cisco PTP stack will use it (this IP associated with this interface) compose the source IP packets containing the UDP messages which contain PTP [ DELAY_REQ ] messages.
In fact, in theory, you can use any random IP address on that BVI.  Just as long as it is not-0.0.0.0, the TCP/IP stack in the PTP GM should not discard it (in theory).  No RFCs specify/dictate that a multicast messages cannot have a source address of 0.0.0.0, in fact, Cisco layer3 switches and routers uses it for DHCP Snooping proxy requests.
We requested our HOPF vendor to fix their firmware to permit source IPv4 address of 0.0.0.0 without discarding them.
We also asked Cisco for a feature to allow us to arbitrarily specify the source address.
If you capture a PCAP /Wireshark on a SPAN port, note the distinction in relation to the PTP packet sequence.  DELAY_REQ with no DELAY_RESP.
Mark Elsen
 -   Following bugs like these : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh88082
                                               https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwf81913
                                             Use latest advisory software version and check if that can help :
                       https://software.cisco.com/download/home/286313851/type/282046477/release/Cupertino-17.9.5
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
bseklecki
This is a CATALYST 9300 or a CATALYST IE-9300 ? The 25gb / TwentyFiveGigE probably indicates the former?
Did you resolve this issue?
