PWR-IE170W-PC-DC Clearance requirement
Blamichhane
I am looking for clearance requirement for installing PWR-IE170W-PC-DC for easy air flow
2 Accepted Solutions
Blamichhane
Hi, I did checked installation guide but could not find actual clearance for power supply. But in the link you provided states
To prevent the switch assembly from overheating, there must be a minimum of 3 inches (76.19 mm) between any other device and the top, bottom, or sides of the switch assembly.
So this is what we need, I guess.
Thanks for the response. I will follow 3 inches clearance rule between devices.
Blamichhane
