QoS for specific website traffic
sudip.acharya1
I want users accessing www.learnlive.com to have priority using QoS.
QoS on our router (connected to our service provider).
QoS on our switch (connected to the router):
class-map match-any LearnLive
  match access-group 90
policy-map QoS
  class LearnLive
   set dscp 31
access-list 90 permit 10.148.0.0 0.0.255.255
The policy has been applied to the physical int, not the vlan int.
Output (not seeing any hits.):
#        sh policy-map interface
FastEthernet0/5
  Service-policy input: QoS
    Class-map: LearnLive (match-any)
      0 packets, 0 bytes
       offered rate 0 bps, drop rate 0 bps
      Match: access-group 90
        0 packets, 0 bytes
         rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
         rate 0 bps
After appliying the qos settings, i see 0 matches when i issue the "sh policy-map interface"
Thanks in advance.
IAN WHITMORE
Level 4
Level 4
And if you apply it to the VLAN interface (L3) and not the switch physical interface (L2)?
cadet alain
If you want to mark traffic you must use an output policy-map.
Regards.
Alain.
I am not able to issue "serv-policy output QoS" to the Vlan interface.
It accepts it but when i do a Sh run, the comand is not issued on the vlan interface. Also, Sh policy-map interface does not return anything.
What is your goal?
Regards.
alain.
