QoS on a non trunk Interface
Tshi M
Level 5
Level 5
I am new to QoS and would like to setup auto QoS between my site and another site. Below is what I intend to implement on my switch (Cisco 6506-e) SUP720. Is this good enough?
switch(config)#mls qos
switch(config)#mls qos map cos-dscp 0 8 16 24 32 46 48 54
switch(config-if)#ip address x.x.x.x/30
switch(config-if)#mls qos trust cos
mihanlin
One suggestion for change:
Instead of mls qos trust cos, do mls qos trust dscp
As CoS is only sent in 802.1q header (i.e. a trunked interface), it won't work. Trusting DSCP will work perfectly for L3 interfaces.
Other than that, what you have there is fine for a basic config.
mihanlin
thanks much for the quick reply.
