Question about Vlan trunking
ciscoadminbw
Frequent Visitor
Frequent Visitor
Hi Guys,
Firewall inside interface 192.168.2.1
Switch 1
Has VLAN 1, IP Address 192.168.2.5 (Device default gateway)
Switch 2
VLAN 200, IP Address 172.17.0.1
I am trying to create a trunk on both switches to carry those 2 vlans. Do i need to create vlan200 on switch 1 as well for me to trunk both vlans?
Any help would be greatly apprecated.
Lake
2 Accepted Solutions
balaji.bandi
yes, if required other side switch required VLAN and device part of VLAN to comunicated this side of VLAN 200 device.
BB
Correct. By doing that, vlan 200 will be part of the trunk in case you need to add a device to it later on that switch.
Reza Sharifi
If you have any end device that is in vlan 200 on switch 1, then you need to add VLAN 200 to the trunk, if not it is not needed, however, it is a good practice to add both VLANs to start with, this way when you add a new device to that switch in VLAN 200, you are already set and ready to go.
Just to be clear, you are saying that i need to create VLAN 200 on both switches and then add VLAN 200 to the trunk? Is that correct?
Lake
balaji.bandi
BB
