Rate Limiting Problem with Cisco C3750G-24PS
Hello all,
I am attempting to perform rate limiting on a sattelite office which has a 10Mb point to point connection back to us.  I understand that I can only rate-limit on incoming traffic, which is fine.  I am trying to limit *Internet traffic* through our proxy server (10.0.47.251).  One of the office users occassionally has to download very large files, and it consumes all available bandwidth, causing the other users a bit of pain and suffering.  And I thought this would be an easy solution?
For whatever reason - my rate limiting is IGNORED.  I am running speed tests (through the proxy server of course) to see if this policy has any affect on or off - and I get no change in the bandwidth.  I am consistently pulling 10Mbps in both directions with or without the policy.
Here are the changes I made:
mls qos
ip access-list extended limit_internet_proxy_traffic_acl
permit ip any host 10.0.47.251
class-map limit_internet_proxy_traffic_cm
match access-group name limit_internet_proxy_traffic_acl
policy-map limit_internet_proxy_traffic_pm
class limit_internet_proxy_traffic_cm
police 2048000 262144 exceed-action drop
!police 6291456 196608 exceed-action drop
int g1/0/24
service-policy input limit_internet_proxy_traffic_pm
And here is the entire config, slightly scrubbed and trimmed:
! Last configuration change at 09:22:49 EST Fri Jun 7 2013
! NVRAM config last updated at 09:22:50 EST Fri Jun 7 2013
version 15.0
no service pad
hostname LittleOffice_C375024PS
boot-start-marker
boot-end-marker
enable secret 5 *SNIP*
no aaa new-model
clock timezone EST -5 0
switch 1 provision ws-c3750g-24ps
system mtu routing 1500
ip domain-name mydomain.local
ip name-server 10.0.47.253
mls qos
crypto pki trustpoint TP-self-signed-2197671040
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2197671040
revocation-check none
rsakeypair TP-self-signed-2197671040
crypto pki certificate chain TP-self-signed-2197671040
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
archive
log config
  logging enable
  logging size 500
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode pvst
vlan internal allocation policy ascending
class-map match-all limit_internet_proxy_traffic_cm
interface GigabitEthernet1/0/1
switchport access vlan 493
switchport mode access
switchport voice vlan 495
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
!!! SNIP SNIP SNIP !!!
interface GigabitEthernet1/0/24
description BRIDGE TO MAIN
switchport mode trunk
speed 100
duplex full
spanning-tree link-type point-to-point
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 10.0.44.250 255.255.252.0
ip default-gateway 10.0.45.1
ip http server
ip http secure-server
logging esm config
snmp-server community mypassword RW
snmp-server enable traps license
line con 0
line vty 0 4
password mysecrettelnet
login
line vty 5 15
login
ntp server 10.0.47.254
end
Lastly, some show version details:
VentureDr_C375024PS# sho ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 15.0(1)SE, RE
LEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 20-Jul-11 09:32 by prod_rel_team
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
VentureDr_C375024PS uptime is 1 week, 3 days, 17 hours, 24 minutes
System restarted at 16:13:14 EST Mon May 27 2013
System image file is "flash:c3750-ipservicesk9-mz.150-1.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24PS (PowerPC405) processor (revision K0) with 131072K bytes of
memory.
Processor board ID FOC1526X1CT
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : D0:C2:82:FD:CC:80
Motherboard assembly number     : 73-10217-10
Power supply part number        : 341-0108-04
Motherboard serial number       : FOC15254MJD
Power supply serial number      : AZS152601KL
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24PS-S
System serial number            : FOC1526X1CT
Top Assembly Part Number        : 800-26855-04
Top Assembly Revision Number    : C0
Version ID                      : V08
CLEI Code Number                : COMB400BRA
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     15.0(1)SE             C3750-IPSERVICESK9-M
Configuration register is 0xF
Thanks for any light you can shed on this.  ;-)
-Steve Ballantyne
paolo bevilacqua
You need to use a router for that, and shaping.
Not a switch, and not rate-limiting (policing).
paolo bevilacqua
You know, I was just mindlessly following instructions and I hadn't really thought about it.
I am trying to create a policy with an IP address on a layer 2 device.  Woops.
Thanks Paolo.  :-)
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A 3750G is a L3 device, and even when not routing, it can examine L3 info.
In your situation, something I'm not sure about is matching L3 information on a trunk interface.
