05-18-2006 05:32 AM - edited 03-05-2019 11:54 AM
Does anybody happen to know if a Cat-2950 or Cat-2980 switches can be rebooted remotely? If they can, what is the command to do it?
Thanks....
05-18-2006 06:20 AM
After logging into the switch, you can just issue the "reload" command. Hope this helps.
04-20-2022 02:12 AM
go to the privillege ,ode inside the switch and type the command reload then press enter button 2 times
Log in to Community
