Recommended Method for Upgrading C9300 Stack
qkrrudgh036
Frequent Visitor
Frequent Visitor
Hi  I’m planning to upgrade a stack of Cisco C9300 switches and would like to ask if there’s a best practice or recommended approach for doing so. The customer has specifically asked whether it’s possible to perform the upgrade without any downtime.
If anyone has experience with this or can share insights on minimizing service disruption during a stack upgrade, I’d really appreciate your input.
Thanks in advance!
Torbjørn
You can use "reloadfast"/Extended Fast Software Upgrade (xFSU) to minimise downtime, but as @Leo Laohoo says above - there will have to be some downtime. See the following documentation: https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216837-extended-fast-software-upgrade-on-cataly.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Leo Laohoo
Not possible in any way, shape or form.  The outage time will depend entire on what is the current firmware and what is the "destination" version.  This is due to a mandatory and automatic micro-code upgrade and the outage time of the micro-code upgrade can vary between 8 to 14 minutes.
Read this:  Cisco 3850: IOS-XE/Firmware Upgrade
Given the current situation, could anyone share the most reliable or recommended upgrade procedure?
Posting this again since nobody bothered to read this the first time:  Cisco 3850: IOS-XE/Firmware Upgrade
Torbjørn
