Redistributing Statics into OSPF and EIGRP
GRANT3779
Hello All,
I am doing some testing with RD'ing statics into both OSPF and EIGRP and I am finding that my neighbour routers are learning the routes via OSPF. Should EIGRP not take preference?
I have a static route which I then reference in a prefix list. I have a route-map matching the prefix list and then RD'ing that into the routing processes (both EIGRP and OSPF).
e.g -
router eigrp 100
 redistribute static metric 100000 1 255 1 1500 route-map TEST
router ospf 1
 redistribute static subnets route-map TEST
The OSPF process always seems to "win" and advertise the route to my neighbour router. Is this using a better metric?
2 Accepted Solutions
Umesh Shetty
EIGRP has two metrics 90- for internal routes ie routes originated within EIGRP (by a network statement) and 170 - for routes redistributed into EIGRP from other routing protocols. OSPF has only one ie 120 for internal and external routes. When you redistribute the same prefix into both processes OSPF (120) is preferred over EIGRP external (120). Hope this answers your question.
Umesh
Umesh,
You're correct but be careful with the administrative distances. OSPF uses 110, not 120 (120 is for RIP).
Best regards,
Peter
Umesh Shetty
Umesh
Umesh,
Best regards,
Peter
Hi Peter,
Sorry for the typo and thanks for correcting. :)
