refresh connection by cli
weiliu8322339
Frequent Visitor
Frequent Visitor
HI,
My Product is C3750.
It was disconnected . How to refresh via cli?
Brgds
Liu Wei
your requirement not clear. use console connection to access device if VTY lines are stucked.
Good luck
KB
5 Replies 5
Good luck
KB
Thanks Kansun, Your advice give me a hint.
It is not accessble from web. I did not try connect via console port.
I prepare console cable.. connet to device by putty. I access and show the running config is correct. Then I reboot the device.
Web port is accessible.
Leo Laohoo
What are you trying to do?
Hi, Leo,
I am a beginner of cisco. I read some information and prepare a console cable. connect to device via putty.
checked and confirm the configuration is correct. Then I reboot the device. Reconnect via network assistant, it does work.
balaji.bandi
You need to explain more, or connect the console cable and check VTY Lines.
BB
