Regarding telnet
ncnaveen_arasu
Level 4
Level 4
HI,
We have a onr remote office and we can't able to take a control of the switch from NOC. Switxh is connected from remote office router.
We can't ping the switch can't telnet the switch even locally. But VLAN were created for few departments and it's working fine.
We found ARP entry for the switch Mangement VLAN IP (vlan 1) is incomplete. It's not getting complete even after claring arp, changing cable, making vlan 1 unshut and reboot.
Please suggest.
Naveen
18 Replies 18
kcnajaf
Level 11
Level 11
Hi Naveen,
Could you please share the config for switch and topology how its connected internally?
Najaf
u unable to ping & telnet locally & Other vlans working ..... do u configured default gateway to switch
Its look like default gateway issue.
HI Thanks for the reply,
We have configured the default gateway also.
mahmoodmkl
Level 11
Level 11
Can u see in the CDP neighbor list of any adjacent device.
Could be that the management IP might have got deleted.
Hi thanks for the reply,
We have the management IP too and we are getting the CDP neighbors mutually. If arp entry found we can able to ping each other. but in router we are getting incomplete entry for VLAN1 IP. what will be the possible reasons for incomplete ARP. can u let us know.
Thanks ,
Naveen
Ok, can you see this switch from another directly-connected switch via CDP or ARP?
HI,
I can see the switch via CDP
Is VLAN 1 enabled on the other switch?
Iincomplete ARP is because the switch is not responding to your ARP requests from the router
Is this switch configured with " ip routing" or using ip default-gateway?
Raju
It would help to know what IP address was used on this switch and in what vlan interface it was configured.
The symptoms suggest that either the switch does not have a management address configured, or that there is something invalid about the configuration of the management address. Perhaps the management address is not in the correct subnet? Or perhaps the management address is not in the correct VLAN?
Perhaps the original poster can post the output of show cdp neighbor detail showing the connection to thsi switch?
Rick
Rick
HI Richard, Thanks for the reply.
Please find the attachmnet for router config and CDP output.
Hi Naveen,
Could you please share the switch configuration.
From the router configuration it looks like this switch is connected to Eth 0/0 (as per CDP output). What is the ip address you have assigned on the switch which connect to this interface?
Najaf
HI Nakaf,
IN the switch trunk interface we have not assigned an IP address as it's an L2 device. We have assgned an IP for the Management VLAN and pointing the default gateway of the switch to the router interface.
Naveen
what is output of sh cdp entry * or sh cdp nei details..... by this u can see neighbor device ip addresses.
