Reintegrating Replacement Switch into VPC Pair: Key Checks
kirank10
"I'm seeking guidance on reintegrating a replacement switch into our production environment following a hardware failure. We utilize a VPC pair configuration, and one switch suffered complete hardware damage. We've obtained a replacement through the RMA process and need to ensure a smooth transition back into the VPC pair. What are the key checks and considerations before reintegrating the replacement switch into the VPC pair?
Many points
But some are
1- check keepalive IP and it VRF
2- check vpc domain must be same
3- most important' stp mode and if you run MST the instances and revisions number must be same
4- feature like
Feature vpc
Feature lacp
Feature interface vlan
Feature hsrp
5- vpc number you use in PO to other SW
6- non-vPC vlan and vPC vlan' this need to know which vlan allow in peer-link
MHM
balaji.bandi
check the technical guide :  (make sure nexus code is same before put them in to live)
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/nexus-7000-series-supervisor-1-module/119033-technote-nexus-00.html
Note : always take the configuration backup out of the box
BB
