removing vpc
toolshed1
Level 2
Level 2
i currently have port-channel with 2 interfaces as members. I would like to dissolve that so interfaces will become individual trunks
Would it be enough for me to go under po1 and do "no vpc 1 ", or would i need to go under gi1/1/1 and gi2/1/1 and do "no channel-group 1 mode active"
int po1
switchport mode trunk
vpc 1
int gi1/1/1
int gi2/1/1
5 Replies 5
balaji.bandi
i suggest to follow below steps :
 int po1  (shutdown)
Then default the interfaces gi1/1/1 and gi2/1/1
then configure fresh config on the interface what ever you like to trunk or access so on.
BB
Thank you.
Should i still do "no vpc 1 " on po1 interface after shutting it down and prior to defaulting physical interfaces?
This will be orphan link? I.e. connect to only one NSK?
MHM
If your intent is to completely remove Port-channel 1, I would delete the Port-channel 1 (no interface port-channel 1) interface after shutting it down and reconfiguring the Gi1/1/1 and Gi2/1/1.  If you are not using the VPC it is not needed.
Richard W. Pidcock
once the ports are removed and defaulted as mentioned above stepts.
if you do not need port-channel 1 - then i simple remove - no interface po 1
BB
