Require EIGRP Full Functionality on 4506E switch - IOS issue
Hello Everyone,
I have a question based on switches IOS. Right now i am working on one setup which has two 4506-E switches with SUP 7E and i want to run EIGRP on this two switches with is connecting to Internet router and PSTN router in full mesh design
When i enable EIGRP on router it works fine but on this switches it automatically enable the command under EIGRP for stub routing as shown in below config.
router eigrp 100
network x.x.x.x
eigrp stub connected summary
From Cisco Switches came with this IOS Image cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin
Later i upgraded the switch with this ios image cat4500e-universalk9.SPA.03.05.01.E.152-1.E1.bin
Still the full funtionality of EIGRP is not supported but SSH worked on both switches which confirms image is upgraded properly. I read on cisco release notes that switch must have enterprise licence to support full EIGRP. Please advise how can i achieve it.
Kindly find the show verson output when the switch received from cisco before upgrading the image.
sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:58 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG5
DC-CORE-SW1 uptime is 2 weeks, 2 days, 23 hours, 23 minutes
System restarted at 02:54:46
Running default software
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
Last reload reason: power-on
License Information for 'WS-X45-SUP7-E'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
cisco WS-C4506-E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FXS1724Q233
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
36 Virtual Ethernet interfaces
72 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
6 Replies 6
daniel.dib
Level 11
Level 11
You need to activate enterprise services license. Here is link how to do it:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/XE3.5.0E/15.21E/configuration/guide/swadmin.html#wp1347232
Here are also some useful links:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/qa_c67-621718.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/at_a_glance_c45-619755.pdf
It seems that you don't have to type in the license any longer which is mutual trust from Cisco that you already got the correct license but it is not enforced.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
Thanks for the reply Daniel
As per your post device already has the licence and it just need enforcement. If i use this command ("license right-to-use activate feature-name") then EIGRP full feature should work.
Am i correct ?
Yes, that's what I figure from the configuration guide. There seems to be a command to set the license level on boot, so have a look at that as well. Wouldn't be nice to have it boot up on IP Base and EIGRP not coming up.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Hi Daniel,
Find below show license all and show version output and i removed the eigrp stub command. its shows that licence is permenent and in use for entservices
sh license all
License Store: Primary License Storage
StoreIndex: 0 Feature: ipbase  Version: 1.0
      License Type: Permanent
      License State: Active, Not in Use
      License Count: Non-Counted
      License Priority: Medium
License Store: Dynamic License Storage
StoreIndex: 0 Feature: entservices  Version: 1.0
      License Type: Evaluation
        Evaluation total period: 8 weeks 4 days
        Evaluation period left: 8 weeks 4 days
      License State: Inactive
      License Priority: None
StoreIndex: 1 Feature: entservices  Version: 1.0
      License Type: PermanentRightToUse
      License State: Active, In Use
StoreIndex: 2 Feature: ipbase  Version: 1.0
StoreIndex: 3 Feature: ipbase  Version: 1.0
sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.05.01.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Sat 23-Nov-13 00:13 by prod_rel_team
ROM: 15.0(1r)SG5
CORE-SW2 uptime is 11 minutes
System returned to ROM by reload
System restarted at 03:04:39 Wed Jan 1 2014
Last reload reason: Reload command
License Level: entservices   Type: Permanent Right-To-Use
Next reboot license Level: entservices
cisco WS-C4506-E (MPC8572) processor (revision 10) with 2097152K bytes of physical memory.
Processor board ID FXS1724Q22W
Last reset from Reload
51 Virtual Ethernet interfaces
Hope its solved the problem and actived the licence entservices form ip base.
I use the following commands.
license right-to-use activate entservices
accept the EULA
conf t
license boot level entservices
wr mem
reload.
verified by using commands
show licence all
show version
removed eigrp stub command which was restricted in ipbase license.
Thanks for your support..
That looks good.
Glad you got it solved. Happy new year!
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Finding difficulty in running EIGRP in
cisco WS-C4506-E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
With SUP 8
System image file is "bootflash:cat4500es8-universalk9.SPA.03.03.01.XO.151-1.XO1.bin"
Im not even seeiing the command router EIGRP in help
