01-21-2019 03:15 PM - edited 03-08-2019 05:06 PM
Please help
Solved! Go to Solution.
01-21-2019 08:26 PM
01-21-2019 03:31 PM
you can look into policy based routing to do some sort of balancing between the two links. seeing you are using static routing, this is probably your easiest option
01-21-2019 05:02 PM
What kind of Datacentre is this Private / Public (what kind of Services offer) ? How big is the Link Capacity.?
As suggested you can do Load Share for the best utilisiation of the links so cost can be recovered, rather making Active / Standby links.
=====️ Preenayamo Vasudevam ️=====
01-21-2019 08:26 PM
01-22-2019 07:28 AM
This is pure L2 ckt, using Cisco router.
@Francesco Molino wrote:
You said you're doing static routing and hsrp, are you managing routers at both ends?
Are those links L2 services or pure L3?
Depending on how these links are managed and what devices you have access to, you can also think about glbp, obviously if there are Cisco devices.
01-22-2019 09:09 PM
06-22-2020 12:49 AM
We have two p2p links from diffrent ISP in between our data center and our HO, connected on two different routers at both ends, we want to load balance traffic on these two links from both ends. We are using static routing and HSRP for failover.
