Restarting my IE4000 16gt-4ge-switch with SNMP (Restart OID is needed)
safaozutemiz
Hi everyone,
I would like to restart my switch using my SNMP server but I could not find any related OIDs on google. Is it possible that anyone could lead me to solve this solution ?
Any idea is appreciated.
Version:15.2(8)E1
andrewswanson
Level 7
Level 7
I've used the following method of restarting switches using snmp:
https://www.ciscozine.com/send-cisco-commands-via-snmp/
From Cisco's SNMP Object Navigator tool, the oid 1.3.6.1.4.1.9.2.9.9 is in OLD-CISCO-TS-MIB - you can also check if your switch SW supports this MIB on the SNMP Object Navigator tool
hth
Andy
AdminMIB
What do u wanna achieve by doing that ? can u be more specific ?
I think it's descriptive enough.
andrewswanson
Level 7
Level 7
hth
Andy
Many Thanks for your response
