Ring topology problem
Alexandre11
Level 5
Level 5
need to change the port ALT in my ring topology using rep
I need to change my ring topology using rep.
Problem with dhcp in client's ring structure
client has a ring topology
client has a ring topology, when we disconnect one side of the ring the dhcp does not work on some machines.
follows the attached image.
by default it locks a port Gi1/0/2 using rep, it is possible for us to define which port we want to block automatically, eg I want to lock gate gi1 / 0/2 of the LDA-COI-SWC126 switch
It's solved, with the commands bellow, in the edge primary port.
interface TenGigabitEthernet1/2
description LDA-SILOS1-SWC134
switchport mode trunk
rep segment 1 edge primary
rep preempt delay 15
rep block port id 00200059DCA1B680 vlan 1-4094
ip dhcp snooping trust
5 Replies 5
nazimkha
Can you post the configs of all the switches.
Which are the edge ports of the REP topology ?
follows the configurations of the attached switches.
Edge Primary - Port T1/2 Switch LDA-4506-GW-TI
Edge Secondary - Port T1/1 Switch LDA-4506-GW-TI
