05-01-2014 07:59 PM - edited 03-07-2019 07:18 PM
I have a 6509 that I've setup with route-maps in order to route VLANs in different ways. For example, if we wanted some vlans to get out to the internet we would route them to a certain address. Then there is another vlan that we route to another internet gateway. It was all working pretty good until we swapped out another switch gateway in the network and every since things have been wonky. It seems as though the switch is routing packets that would normally stay on that switch out of the switch then back in, even though my access-list are set to deny the traffic. Here are the access-list and route-maps:
access-list 10 permit 192.168.24.101
access-list 10 permit 192.168.24.102
access-list 100 permit tcp any 172.16.0.0 0.0.255.255 established
access-list 100 permit tcp 192.168.4.0 0.0.3.255 host 172.16.1.10 eq www
access-list 100 permit tcp 192.168.4.0 0.0.3.255 host 172.16.1.11 eq www
access-list 104 permit ip host 172.16.4.11 host 65.54.150.19
access-list 104 permit tcp host 172.16.4.20 any eq www
ip access-list extended BITCENTRAL_INTERNET
deny ip 172.16.0.0 0.0.255.255 172.16.0.0 0.0.255.255
deny ip 172.16.0.0 0.0.255.255 192.168.4.0 0.0.3.255
deny ip 192.168.4.0 0.0.3.255 172.16.0.0 0.0.255.255
permit ip host 172.16.1.170 any
permit ip host 172.16.1.150 any
ip access-list extended EDIT_BAYS
deny ip any 172.16.0.0 0.0.255.255
deny ip 172.16.0.0 0.0.255.255 any
permit ip host 192.168.25.2 any
permit ip host 192.168.26.80 any
permit ip host 192.168.25.104 any
permit ip host 192.168.25.3 any
permit ip host 192.168.26.69 any
permit ip host 192.168.26.71 any
permit ip host 192.168.27.33 any
ip access-list extended ENPS
permit ip host 192.168.24.101 any
permit ip host 192.168.24.102 any
permit ip host 192.168.24.103 any
ip access-list extended ENTRIQ
deny ip 172.16.0.0 0.0.255.255 192.168.24.0 0.0.3.255
deny ip 192.168.24.0 0.0.3.255 172.16.0.0 0.0.255.255
permit ip 172.16.8.0 0.0.0.255 any
ip access-list extended MISC
permit ip 172.16.11.0 0.0.0.255 any
ip access-list extended Omneon
permit ip host 172.16.2.11 any
permit ip host 172.16.2.2 any
ip access-list extended ROSS-VLAN
permit ip host 172.16.4.20 any
permit ip host 172.16.4.32 any
permit ip host 172.16.4.31 any
permit ip host 172.16.4.29 any
permit ip host 172.16.4.30 any
permit ip host 172.16.4.28 any
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 172.16.1.1 255.255.255.0
ip policy route-map BITCENTRAL
interface Vlan20
ip address 172.16.2.1 255.255.255.0
ip policy route-map OMNEON
interface Vlan30
ip address 172.16.3.1 255.255.255.0
interface Vlan40
ip address 172.16.4.1 255.255.255.0
ip policy route-map ROSS-VLAN
interface Vlan50
ip address 172.16.5.1 255.255.255.0
interface Vlan60
ip address 172.16.6.1 255.255.255.0
interface Vlan70
ip address 172.16.7.1 255.255.255.0
interface Vlan80
ip address 172.16.8.1 255.255.255.0
ip policy route-map ENTRIQ
interface Vlan100
ip address 192.168.27.1 255.255.252.0
ip helper-address 192.168.7.255
ip policy route-map OMNIBUS-VLAN
interface Vlan110
ip address 172.16.11.1 255.255.255.0
ip helper-address 192.168.27.200
ip policy route-map MISC
interface Vlan120
ip address 172.16.10.1 255.255.255.240
ip policy route-map EDIT_BAYS
interface Vlan140
ip address 192.168.4.15 255.255.255.0
ip directed-broadcast 10
interface Vlan500
ip address 192.168.1.19 255.255.255.224
ip classless
ip route 172.22.0.0 255.255.255.248 192.168.4.1
ip route 192.168.0.0 255.255.255.224 192.168.4.254
ip route 192.168.5.0 255.255.255.0 192.168.4.1
route-map BITCENTRAL permit 60
match ip address BITCENTRAL_INTERNET
set ip next-hop 192.168.4.1
route-map EDIT_BAYS permit 50
match ip address EDIT_BAYS
route-map ENTRIQ permit 80
match ip address ENTRIQ
set ip next-hop 172.16.8.254
route-map MISC permit 40
match ip address MISC
route-map MSN permit 10
match ip address 104
route-map OMNEON permit 20
match ip address Omneon
route-map OMNIBUS-VLAN permit 30
route-map OMNIBUS-VLAN permit 40
match ip address ENPS
route-map ROSS-VLAN permit 70
match ip address ROSS-VLAN
route-map SEC-VLAN permit 30
match ip address SEC-VLAN
Here is how we tested the system and found the error. We cut the connection to 192.168.4.1 router, and when we try to ping a host on the 100 VLAN with the ip address of 192.168.24.101 from the MISC vlan with a ip address of 172.168.11.9 the ping just fails. When we enable the connection to the 192.168.4.1 router the pings go through again. What in my route-map is causing this, I thought I setup the deny rules pretty good?
05-02-2014 12:11 PM
Hi Mike,
Between you and me, this is a lengthy config you have there.
Next don't forget that a route-map doesn't apply to traffic originated or destined to the self-device, unless you use ip local policy in which might work, but there I have seen some nasty bugs.
So if you can shorten your config to one example, then do the tests :
- sourced from device A (it can be the SVI of another switch)
- through your 6509
- destined to device B (it also can be the SVI of another switch, or even simpler some loopback inteface).
