08-09-2011 10:04 AM - edited 03-07-2019 01:37 AM
Dear Sir,
We are having problems with our core router 72076VXR NPE-G1.
Our router have a BGP routing protocol to propagate internal network and communicate with other external router.
Also, this router have static routes with a different weight to support backup to networks learned by BGP protocol.
For example:
PROBLEM:
The router is choosing the static route instead of the BGP route and this is producing problems in the network.
Somebody tell us why the router give more preference to static routes instead the BGP routing which has a weight less than static route?
We are annexing the sh ver and routing BGP configuration of the router.
Can it be associated to a BUG Software for the actual IOS?.
Waiting any help.
Attn.
Roger Majo
08-09-2011 10:17 AM
First option within the BGP Best Path Algorithm is to select the WEIGHT. Highest WEIGHT is preferred.
By default, when redistributing into BGP the originated route will have a WEIGHT of 32768.
If you want the BGP learned prefix to be preferred over the static route, you need to modify your inbound route-map to set the WEIGHT to a value greater than 32768.
Edison
08-09-2011 10:24 AM
From the output I can see there are several routes with weight of 250. However, most routes have no weight configured and will hence use the default of 1, which is less than eBGP.
Presumably your problem is with the static routes that do have a weight configured, yes?
In that case, please provide the output sh ip bgp for us in order to verify the bgp routes overruling the statics with w=250 are actually there. A bug is not likely, Cisco's BGP implementation is very stable and mature.
regards,
Leo
08-09-2011 10:44 AM
Huh?
You are confusing the Metric (MED) with the WEIGHT. The WEIGHT is not introduced from the IGP metric.
08-09-2011 11:18 AM
Hi Edison,
I was talking about the static routes provided with the starting post.
Some of these have a weight of 250 configured, most are 'normal' static routes.
regards,
Leo
08-09-2011 11:29 AM
I call that Admin Distance, but that's just me
08-09-2011 10:50 AM
Leo.
As follow la information requested:
sh ip bgp
BGP table version is 48799, local router ID is 10.254.1.241
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
r> 0.0.0.0 10.145.1.249 0 150 35000 6147 i
*> 7.2.10.21/32 10.1.200.4 0 80 32768 ?
*> 7.2.10.22/32 10.1.200.4 0 80 32768 ?
*> 8.2.17.22/32 10.1.200.4 0 80 32768 ?
*> 8.17.2.10/32 10.1.200.4 0 80 32768 ?
*> 9.9.9.0/30 10.145.1.249 150 35000 6147 ?
*> 10.1.0.0/16 0.0.0.0 0 32768 i
*> 10.1.200.101/32 0.0.0.0 0 80 32768 ?
*> 10.1.231.10/32 10.1.200.132 0 80 32768 ?
*> 10.2.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.2.106.11/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.2.106.60/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.2.106.70/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.2.106.80/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.3.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.4.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.5.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.5.136.10/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.6.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.7.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.10.200.0/30 0.0.0.0 0 32768 i
*> 10.12.200.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.13.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.14.200.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.16.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.17.0.0/16 10.1.200.132 0 80 32768 ?
*> 10.18.0.0/16 10.1.200.132 0 80 32768 ?
*> 10.19.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.20.0.0/16 10.1.200.7 0 80 32768 ?
*> 10.21.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.22.200.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.23.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.24.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.26.0.0/16 10.145.1.249 150 35000 6147 i
*> 10.27.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.28.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.29.200.0/30 10.145.1.249 150 35000 6147 6147 ?
*> 10.33.200.14/32 0.0.0.0 0 80 32768 ?
*> 10.34.0.0/16 10.1.200.4 0 80 32768 ?
*> 10.41.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.45.1.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.49.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.50.0.0/16 10.1.200.4 0 80 32768 ?
*> 10.51.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.52.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.53.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.54.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.55.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.60.1.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.60.2.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.60.3.0/24 10.1.200.132 0 80 32768 ?
*> 10.60.4.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.60.5.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.60.7.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.60.8.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.60.9.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.61.1.0/24 10.1.200.132 0 80 32768 ?
*> 10.61.2.0/24 10.1.200.132 0 80 32768 ?
*> 10.62.40.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.62.41.112/29 10.145.1.249 150 35000 6147 6147 i
*> 10.70.0.0/16 10.1.104.64 0 80 32768 ?
*> 10.71.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.72.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.73.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.74.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.77.0.0/16 10.1.200.34 0 80 32768 ?
*> 10.78.0.0/16 10.1.106.1 0 80 32768 ?
*> 10.80.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.81.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.82.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.83.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.85.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.88.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.90.0.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.1.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.2.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.3.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.4.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.5.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.6.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.7.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.8.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.9.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.10.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.11.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.12.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.13.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.14.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.15.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.16.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.17.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.18.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.19.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.20.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.21.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.90.22.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.90.23.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.24.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.25.0/24 10.1.200.132 0 80 32768 ?
*> 10.90.26.0/24 10.1.200.132 0 80 32768 ?
*> 10.94.101.0/24 10.1.200.132 0 80 32768 ?
*> 10.94.106.0/24 10.1.200.132 0 80 32768 ?
*> 10.94.230.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.95.0.0/16 10.1.200.132 0 80 32768 ?
*> 10.96.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.97.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.98.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.99.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.100.0.0/16 0.0.0.0 0 32768 i
*> 10.100.101.48/32 0.0.0.0 0 32768 i
*> 10.101.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.102.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.102.254.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 10.103.0.0/16 10.145.1.249 150 35000 6147 6147 ?
*> 10.110.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.111.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.112.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.120.2.0/27 10.145.1.249 150 35000 6147 i
*> 10.120.3.0/27 10.145.1.249 150 35000 6147 i
*> 10.120.8.0/24 10.145.1.249 150 35000 6147 ?
*> 10.120.9.0/24 10.145.1.249 150 35000 6147 ?
*> 10.120.10.1/32 10.145.1.249 150 35000 6147 ?
*> 10.125.25.0/24 10.145.1.249 150 35000 6147 i
*> 10.125.26.0/30 10.145.1.249 150 35000 6147 ?
*> 10.125.27.0/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.8/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.12/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.13/32 10.145.1.249 150 35000 6147 6147 ?
*> 10.128.1.16/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.20/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.22/32 10.145.1.249 150 35000 6147 ?
*> 10.128.1.24/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.40/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.48/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.60/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.64/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.68/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.80/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.84/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.86/32 10.145.1.249 150 35000 6147 ?
*> 10.128.1.88/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.110/32 10.1.200.15 0 80 32768 ?
*> 10.128.1.116/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.125/32 10.145.1.249 150 35000 6147 ?
*> 10.128.1.133/32 10.145.1.249 150 35000 6147 ?
*> 10.128.1.136/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.140/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.144/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.156/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.176/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.178/32 10.145.1.249 150 35000 6147 ?
*> 10.128.1.240/30 10.145.1.249 150 35000 6147 ?
*> 10.128.1.244/30 10.145.1.249 150 35000 6147 ?
*> 10.128.199.236/30
10.145.1.249 200 150 35000 6147 ?
*> 10.128.199.252/30
*> 10.128.206.64/30 10.145.1.249 150 35000 6147 ?
*> 10.128.206.66/32 10.145.1.249 150 35000 6147 ?
*> 10.128.206.68/30 10.145.1.249 150 35000 6147 ?
*> 10.128.206.72/30 10.145.1.249 150 35000 6147 ?
*> 10.129.1.36/30 10.145.1.249 150 35000 6147 ?
*> 10.129.1.48/30 10.145.1.249 200 150 35000 6147 ?
*> 10.129.1.56/30 10.145.1.249 150 35000 6147 ?
*> 10.129.1.60/30 10.145.1.249 150 35000 6147 ?
*> 10.129.1.80/30 10.145.1.249 150 35000 6147 ?
*> 10.129.218.224/30
*> 10.130.1.0/24 10.1.240.1 0 80 32768 ?
*> 10.130.2.0/24 10.1.240.1 0 80 32768 ?
*> 10.130.3.0/24 10.1.240.1 0 80 32768 ?
*> 10.130.4.0/24 10.1.240.1 0 80 32768 ?
*> 10.130.5.0/24 10.1.240.1 0 80 32768 ?
*> 10.130.32.0/24 10.1.240.1 0 80 32768 ?
*> 10.131.1.0/30 10.145.1.249 150 35000 6147 ?
*> 10.131.1.2/32 10.145.1.249 150 35000 6147 ?
*> 10.131.1.4/30 10.145.1.249 150 35000 6147 ?
*> 10.131.1.8/30 10.145.1.249 150 35000 6147 ?
*> 10.131.1.12/30 10.145.1.249 150 35000 6147 ?
*> 10.131.1.20/30 10.145.1.249 150 35000 6147 ?
*> 10.131.1.22/32 10.145.1.249 150 35000 6147 ?
*> 10.131.1.24/30 10.145.1.249 150 35000 6147 ?
*> 10.132.0.0/19 10.1.200.9 0 80 32768 ?
*> 10.144.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.145.1.0/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.16/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.24/30 10.145.1.249 200 150 35000 6147 ?
*> 10.145.1.32/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.40/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.48/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.50/32 10.145.1.249 150 35000 6147 ?
*> 10.145.1.52/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.72/30 10.145.1.249 200 150 35000 6147 ?
*> 10.145.1.76/30 10.145.1.249 200 150 35000 6147 ?
*> 10.145.1.92/30 10.145.1.249 150 35000 6147 ?
*> 10.145.1.100/30 10.145.1.249 150 35000 6147 ?
r> 10.145.1.248/30 10.145.1.249 200 150 35000 6147 ?
*> 10.145.1.252/30 10.145.1.249 150 35000 6147 ?
*> 10.147.1.252/30 10.145.1.249 200 150 35000 6147 ?
*> 10.150.0.0/19 10.1.200.9 0 80 32768 ?
*> 10.150.32.0/19 10.1.200.9 0 80 32768 ?
*> 10.150.64.0/19 10.1.200.9 0 80 32768 ?
*> 10.150.96.0/19 10.1.200.9 0 80 32768 ?
*> 10.150.128.0/19 10.1.200.9 0 80 32768 ?
*> 10.152.0.0/19 10.1.200.9 0 80 32768 ?
*> 10.152.32.0/19 10.1.200.9 0 80 32768 ?
*> 10.154.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.155.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.156.0.0/16 10.1.200.9 0 80 32768 ?
*> 10.160.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.160.1.16/30 10.145.1.249 150 35000 6147 ?
*> 10.160.1.20/30 10.145.1.249 150 35000 6147 ?
*> 10.160.231.16/29 10.145.1.249 150 35000 6147 ?
*> 10.160.231.102/32
*> 10.163.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.170.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.180.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.183.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.184.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.190.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.191.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.192.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.192.196.112/30
*> 10.193.1.4/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.16/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.24/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.36/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.52/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.56/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.58/32 10.145.1.249 150 35000 6147 ?
*> 10.193.1.60/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.64/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.68/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.70/32 10.145.1.249 150 35000 6147 ?
*> 10.193.1.84/30 10.145.1.249 150 35000 6147 ?
*> 10.193.1.128/29 10.145.1.249 150 35000 6147 ?
*> 10.193.199.232/30
*> 10.195.1.0/30 10.145.1.249 150 35000 6147 ?
*> 10.195.1.8/30 10.145.1.249 150 35000 6147 ?
*> 10.195.221.96/30 10.145.1.249 150 35000 6147 ?
*> 10.197.1.0/30 10.145.1.249 150 35000 6147 ?
*> 10.197.1.2/32 10.145.1.249 150 35000 6147 ?
*> 10.200.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.203.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.207.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.209.1.0/30 10.145.1.249 150 35000 6147 ?
*> 10.209.1.56/30 10.145.1.249 150 35000 6147 ?
*> 10.211.1.32/30 10.145.1.249 150 35000 6147 ?
*> 10.211.1.34/32 10.145.1.249 150 35000 6147 ?
*> 10.212.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.213.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.215.1.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.215.2.0/24 10.145.1.249 150 35000 6147 ?
*> 10.215.254.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.222.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.224.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.225.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.227.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.230.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.231.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.232.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.233.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.234.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.236.1.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.236.254.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.237.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.238.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.239.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.240.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.241.0.0/16 10.145.1.249 150 35000 6147 ?
*> 10.242.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.244.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.245.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.246.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.247.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 10.248.231.32/27 10.1.106.1 0 80 32768 ?
*> 10.248.231.128/25
*> 10.249.1.0/24 10.145.1.249 150 35000 6147 ?
*> 10.252.2.0/24 10.145.1.249 150 35000 6147 6147 i
*> 10.254.1.8/30 10.145.1.249 150 35000 6147 6147 ?
*> 10.254.1.16/30 10.145.1.249 150 35000 6147 ?
*> 10.254.1.27/32 10.1.200.132 0 80 32768 ?
*> 10.254.1.32/29 0.0.0.0 0 80 32768 ?
*> 10.254.3.0/30 10.1.200.4 0 80 32768 ?
*> 11.1.0.0/16 10.100.106.240 0 80 32768 ?
*> 11.2.0.0/16 10.100.106.240 0 80 32768 ?
*> 11.3.0.0/16 10.100.106.240 0 80 32768 ?
*> 15.1.1.0/24 10.1.200.5 0 80 32768 ?
*> 15.2.1.0/24 10.1.200.15 0 80 32768 ?
*> 18.2.0.0/16 10.1.200.4 0 80 32768 ?
*> 20.2.0.0/16 10.1.231.150 0 80 32768 ?
*> 20.20.0.0/16 10.145.1.249 150 35000 6147 6147 i
*> 20.20.10.0/24 10.1.230.30 0 80 32768 ?
*> 20.215.0.0/16 0.0.0.0 0 80 32768 ?
*> 38.118.139.17/32 10.1.200.19 0 80 32768 ?
*> 69.28.159.41/32 10.1.200.19 0 80 32768 ?
*> 69.184.0.0/16 10.1.240.15 0 80 32768 ?
*> 69.191.192.0/18 10.1.240.15 0 80 32768 ?
*> 69.192.134.54/32 10.1.240.15 0 80 32768 ?
*> 72.246.64.16/32 10.1.240.15 0 80 32768 ?
*> 72.246.64.34/32 10.1.240.15 0 80 32768 ?
*> 72.247.26.54/32 10.1.240.15 0 80 32768 ?
*> 96.16.86.54/32 10.1.240.15 0 80 32768 ?
*> 96.17.86.54/32 10.1.240.15 0 80 32768 ?
*> 128.1.6.0/24 10.1.240.1 0 80 32768 ?
*> 128.4.1.0/24 10.1.240.1 0 80 32768 ?
*> 129.39.178.16/28 10.145.1.249 150 35000 6147 6147 i
*> 129.39.179.46/32 10.145.1.249 150 35000 6147 6147 ?
*> 130.1.0.0 10.1.240.1 0 80 32768 ?
*> 130.1.16.77/32 10.1.240.1 0 80 32768 ?
*> 134.162.22.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 148.244.45.46/32 10.1.240.15 0 80 32768 ?
*> 150.4.5.0/24 10.1.200.4 0 80 32768 ?
*> 150.4.5.1/32 10.1.200.4 0 80 32768 ?
*> 150.4.5.15/32 10.1.200.4 0 80 32768 ?
*> 150.4.5.41/32 10.1.200.4 0 80 32768 ?
*> 160.43.250.0/24 10.1.240.15 0 80 32768 ?
*> 160.120.0.0 10.1.200.4 0 80 32768 ?
*> 160.130.0.0 10.1.200.4 0 80 32768 ?
*> 165.183.150.0/24 10.1.200.4 0 80 32768 ?
*> 167.110.116.0/22 10.145.1.249 150 35000 6147 6147 i
r 172.16.0.0 10.1.240.1 0 80 32768 ?
r> 10.145.1.249 150 35000 6147 6147 ?
*> 172.17.0.0 10.1.240.1 0 80 32768 ?
*> 172.18.1.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.10.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.12.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.16.0/24 10.145.1.249 150 35000 6147 ?
*> 172.18.100.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.101.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.102.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.103.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.104.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.105.0/24 10.1.240.1 0 80 32768 ?
*> 172.18.150.0/24 10.1.200.9 0 80 32768 ?
*> 172.18.151.0/24 10.1.200.9 0 80 32768 ?
*> 172.18.152.0/24 10.1.200.9 0 80 32768 ?
*> 172.18.153.0/24 10.1.200.9 0 80 32768 ?
*> 172.18.200.0/24 10.1.240.1 0 80 32768 ?
*> 172.20.0.0 10.145.1.249 150 35000 6147 i
*> 172.24.111.0/24 10.1.240.1 0 80 32768 ?
*> 172.24.251.0/24 10.145.1.249 150 35000 6147 6147 ?
*> 172.25.78.0/24 10.1.104.63 0 80 32768 ?
*> 172.26.101.0/24 10.1.240.1 0 80 32768 ?
*> 172.30.49.0/24 10.1.240.5 0 80 32768 ?
*> 172.31.0.0 10.1.240.10 0 80 32768 ?
*> 180.1.1.0/24 10.1.200.19 0 80 32768 ?
*> 184.50.214.54/32 10.1.240.15 0 80 32768 ?
*> 190.12.83.141/32 10.1.240.15 0 80 32768 ?
*> 192.9.200.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.165.211.1/32 10.1.240.15 0 80 32768 ?
*> 192.165.211.2/32 10.1.240.15 0 80 32768 ?
*> 192.165.211.3/32 10.1.240.15 0 80 32768 ?
*> 192.168.0.0 10.1.200.9 0 80 32768 ?
*> 192.168.1.0 10.1.200.9 0 80 32768 ?
*> 192.168.1.101/32 10.1.200.9 0 80 32768 ?
*> 192.168.2.0 10.1.200.9 0 80 32768 ?
*> 192.168.4.0 10.1.200.9 0 80 32768 ?
r> 192.168.10.0 10.145.1.249 150 35000 6147 6147 i
r 10.100.200.1 0 80 32768 ?
*> 192.168.12.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.12.21/32 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.13.0 10.145.1.249 150 35000 6147 6147 i
*> 192.168.16.0/29 10.145.1.249 150 35000 6147 ?
*> 192.168.20.2/32 10.100.200.1 0 80 32768 ?
*> 192.168.20.10/32 10.100.200.1 0 80 32768 ?
*> 192.168.22.0 10.1.200.10 0 80 32768 ?
*> 192.168.30.0 10.100.200.1 0 80 32768 ?
*> 192.168.40.0 10.145.1.249 150 35000 6147 ?
*> 192.168.40.1/32 10.145.1.249 150 35000 6147 ?
*> 192.168.45.50/32 10.1.200.132 0 80 32768 ?
*> 192.168.52.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.80.0 10.1.200.4 0 80 32768 ?
*> 192.168.92.0 10.145.1.249 150 35000 6147 ?
*> 192.168.92.10/32 10.145.1.249 150 35000 6147 ?
*> 192.168.92.11/32 10.145.1.249 150 35000 6147 ?
*> 192.168.103.0 10.145.1.249 150 35000 6147 ?
*> 192.168.104.0 10.1.240.1 0 32768 ?
*> 192.168.104.101/32
*> 192.168.104.110/32
*> 192.168.104.200/32
*> 192.168.104.201/32
*> 192.168.105.0 10.145.1.249 150 35000 6147 ?
*> 192.168.106.0 10.145.1.249 150 35000 6147 ?
*> 192.168.108.0 10.1.240.5 0 80 32768 ?
*> 192.168.185.0 10.1.200.132 0 80 32768 ?
*> 192.168.197.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.198.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.199.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.200.0 10.145.1.249 150 35000 6147 6147 ?
*> 192.168.200.201/32
r 192.168.201.0 10.1.240.1 0 80 32768 ?
*> 192.168.202.0 10.1.240.1 0 80 32768 ?
*> 192.168.208.0/23 10.1.240.5 0 80 32768 ?
*> 192.168.210.0 10.145.1.249 150 35000 6147 ?
*> 192.168.211.0 10.1.240.5 0 80 32768 ?
*> 192.168.220.0 10.1.200.132 0 80 32768 ?
*> 192.193.232.113/32
*> 193.163.252.178/32
*> 193.163.252.179/32
*> 199.67.185.130/32
*> 199.105.176.0/21 10.1.240.15 0 80 32768 ?
*> 199.105.184.0/23 10.1.240.15 0 80 32768 ?
*> 200.1.129.133/32 10.145.1.249 150 35000 6147 6147 ?
*> 200.4.200.145/32 10.1.240.15 0 80 32768 ?
*> 200.4.200.150/32 10.1.240.15 0 80 32768 ?
*> 200.4.200.170/32 10.1.240.15 0 80 32768 ?
*> 200.4.200.176/32 10.1.240.15 0 80 32768 ?
*> 200.4.206.20/32 10.1.240.15 0 80 32768 ?
*> 200.10.75.109/32 10.1.240.15 0 80 32768 ?
*> 200.37.27.145/32 10.1.240.15 0 80 32768 ?
*> 200.37.27.170/32 10.1.240.15 0 80 32768 ?
*> 200.37.27.176/32 10.1.240.15 0 80 32768 ?
*> 200.37.58.150/32 10.1.240.15 0 80 32768 ?
*> 200.37.138.28/32 10.1.240.15 0 80 32768 ?
*> 200.37.234.100/32
*> 200.37.254.101/32
*> 200.38.120.27/32 10.1.240.15 0 80 32768 ?
*> 200.48.7.11/32 10.1.240.15 0 80 32768 ?
*> 200.48.16.36/32 10.1.240.15 0 80 32768 ?
*> 200.60.52.90/32 10.1.240.15 0 80 32768 ?
*> 200.62.224.164/32
*> 200.62.224.170/32
*> 200.89.31.0 10.100.200.1 0 80 32768 ?
*> 200.123.1.2/32 10.1.240.15 0 80 32768 ?
*> 200.123.1.11/32 10.1.240.15 0 80 32768 ?
*> 201.224.75.138/32
*> 201.234.61.0 10.100.200.1 0 80 32768 ?
*> 204.79.199.2/32 10.1.200.8 0 80 32768 ?
*> 205.183.246.0 10.1.240.15 0 80 32768 ?
*> 205.188.215.229/32
10.1.200.25 0 80 32768 ?
*> 205.216.112.0 10.1.240.15 0 80 32768 ?
*> 206.156.53.0 10.1.240.15 0 80 32768 ?
*> 208.22.56.0 10.1.240.15 0 80 32768 ?
*> 208.22.57.0 10.1.240.15 0 80 32768 ?
*> 208.134.161.0 10.1.240.15 0 80 32768 ?
*> 209.17.220.0 10.1.106.1 0 80 32768 ?
*> 209.17.220.1/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.3/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.8/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.9/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.25/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.31/32 10.1.200.132 0 80 32768 ?
*> 209.17.220.37/32 10.1.200.132 0 80 32768 ?
*> 216.244.140.70/32
10.1.200.55 0 80 32768 ?
*> 216.244.162.240/32
*> 216.244.165.234/32
*> 216.244.165.240/32
*> 216.244.172.154/32
Sitel-71362#
regards,
Leo
regards,
Leo
08-09-2011 10:57 AM
Ah!, You were referring to Admin Distance, NOT BGP Weight!
Well, I checked your attached files and I don't see a static route for 10.16.0.0/16 hence the BGP route will be chosen.
If you were to add the static route as backup to BGP, this is the command
ip route 10.16.0.0 255.255.0.0 250 10.1.140.5 30
Where 30 is greater than eBGP's AD of 20.
08-09-2011 11:10 AM
Edison.
You are rigth.
There is not any static route associated to 10.16.0.0 /16 with a metric of 250.
We erased those static routes because the router choose the static route instead of the BGP route.
if we put again a static route for example:
ip route 10.16.0.0 255.255.0.0 10.1.140.5 30 or
ip route 10.16.0.0 255.255.0.0 10.1.140.5 250
the router will choose those instead of BGP.
This is the problem we are having.
We are planning to reset (power down and power up) the router to erase any unstable behavior of it.
Waiting your answer.
Attn.-
Roger Majo
08-09-2011 11:28 AM
Roger,
When you put the static route, please provide the output from typing:
show ip route 10.16.0.0
and
show ip bgp 10.16.0.0
Edison
08-09-2011 11:52 AM
Hi Roger,
Would it be possible for you to post the following commands from your existing device when there is no static route and also after you enter the static route.
"show ip route 10.16.0.0"
"show ip route 10.145.1.249"
"show ip route 10.1.140.5"
"show ip int brief"
Thx
