routing intervlan
rchapotin
Community Member
I have a problem with inter-vlan, on my routage table
Cisco1# show ip route
Maximum Parallel Paths: 1 (1 after reset)
Codes: C - connected, S - static
S  0.0.0.0/0          [1/1] via  192.168.100.250  0:14:26          vlan 1
C  192.168.100.0/24   is directly connected                        vlan 1
my vlan 10 is not here.
Cisco1# show vlan
Vlan       Name                   Ports                Type     Authorization
1           1            g(5-10,13-22),ch(1-8)       other       Required
10       Serveur                g(1-4)             permanent     Required
20   Administration                                permanent     Required
30   Salle de soins                                permanent     Required
40       Cuisine                                   permanent     Required
50        Soins                                    permanent     Required
Cisco1# show ip int
Proxy ARP is disabled
      IP Address                I/F            Type     Directed   Precedence
                                                        Broadcast
192.168.10.254/24       vlan 10              Static    disable     No
192.168.100.254/24      vlan 1               Static    disable     No
If you have an idea. Thank you in advance.
9 Replies 9
Could you elaborate what you want to achieve and also I think your question is a bit vague.
Explain your set up and what you want to achieve?
Ven Taylor
Level 8
Level 8
Do you have no auto-summary in your routing process?
Ven
Ven Taylor
jimmysands73_2
Level 9
Level 9
I think he might be asking why the SVI he created isnt in the routing table...maybe?
rchapotin
Community Member
Yes jimmysands, i don't know why my vlan 10 is not present in the routage table. And I would like my vlan communicate with each other via the switch internally.
PS: I'm sorry for my english, i'm french ^^
Did you configure any routing protocol? if yes which one?
can you do a show ip prot
rchapotin
Community Member
I do not use a routing protocol and the command show ip prot is not available
I found my problem, it was necessary to connect a PC to a port of vlan.
S  0.0.0.0/0          [1/1] via  192.168.100.250  0:36:56          vlan 1
C  192.168.10.0/24    is directly connected                        vlan 10
Cisco1#
The ping don't always pass between the two vlan.
Hi Raphael,
Based on that you probably suffered from a feature called "autostate", basically a Virtual interface (SVI) that handles Vlan traffic will not come "up" or list in the routing table until at least one member port in that Vlan is connected.
See:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080160b14.shtml
Duncan.
rchapotin
Community Member
Thank you everyone for your help. This official perfectly
