RSPAN at Nexus 9K
I have read that N9K doesn’t support RSPAN but I see at my boxes that the vlan 666 is a remote span.
What is more interesting that is working fine however I don’t know how vlan 666 was defined.
I ask because nowadays I couldn't  create next remote vlan ie. Vlan 669 as a remote span.
nexus9k-1 (config)# vlan 669
nexus9k-1 (config-vlan)# remote-span
                                                   ^% Invalid command at '^' marker.
nexus9k-1# sho version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2017, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
  BIOS: version 07.51
  NXOS: version 7.0(3)I4(6)
  BIOS compile time:  02/15/2016
  NXOS image file is: bootflash:///nxos.7.0.3.I4.6.bin
  NXOS compile time:  3/9/2017 22:00:00 [03/10/2017 08:05:18]
Hardware
  cisco Nexus9000 C9372PX chassis
  Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16401416 kB of memory.
  Processor Board ID FDO20390GJM
  Device name: nexus9k-1
  bootflash:   53298520 kB
Kernel uptime is 48 day(s), 3 hour(s), 34 minute(s), 7 second(s)
Last reset at 592986 usecs after  Wed Mar 29 07:00:03 2017
  Reason: Reset due to upgrade
  System version: 7.0(3)I2(2)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Active Package(s):
Nexus-1# sho vl
VLAN Name                             Status    Ports
1    default                          active    Po3, Po4, Po5, Po6, Po9, Po49
                                                Eth1/3, Eth1/4, Eth1/5, Eth1/6
                                                Eth1/7, Eth1/8, Eth1/9, Eth1/10
622                                               active    Po3, Po4, Po5, Po6, Po9, Po49
<snip>
653  enet         CE
666  enet         CE
3966 enet         CE
Remote SPAN VLANs
666
5 Replies 5
Diana Karolina Rojas
Hello!
It is strange, how is your configuration in your source and destination switches for that vlan? how is your monitor sesion configured? You can configure  a vlan like a source with a ERSPAN configuration, I invite you to read this Cisco document: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide_7x_chapter_010001.pdf
---Do not forget to rate useful post---
I know it  is strange but  in my case I don’t want to use nexus 9K as source or destination monitor session. I want to use them as transit network for RSPAN VLAN in my case it is the VLAN 666.
Diagram1.
Catalyst 3650 (sw1)======VPC=====N9K[1-2] =====VPC=====Catalyst 3650(sw2).
I need to monitor traffic between ports at sw1 and send copy to port at sw2.  So  As you see I need RSPAN vlan at N9K.
Best
Rico
 I have a similar situation and wanted to ask if this scenario works fine with you finally? if Yes, please send me the details of your switches configuration.
Thanks.
I would also like to use my nexus 9k as a transit network for RSPAN VLANs.
I have (2960)-----(9K VPC)-----(2960).
I can create the RPSAN VLANs on the 2960s.  I can not create the VLAN as an RSPAN on the 9Ks.
Were you able to figure out how you got this working and could you please share your results with me.
Allen
Hello
Is this working, I am facing same issue, 2960x >> N9k >>> 2960x.
I am also not able to create RSPAN vlan in 2960 switch, is it required license. Currently Lanbase is installed.
Index 1 Feature: lanlite
        Period left: 0  minute  0  second
Index 2 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
Kamlesh
