RSPAN, SPAN on same switch
Michael Meyer
Level 2
Level 2
Hi All
I have two switches (2960S's) both with IP Phones on VLAN100
We need to monitor voice traffic via a monitor port on SW1 of all VLAN100 traffic on both switches.
The following is what we have configured, but we cannot see VLAN100 traffic on SW1
SW2
monitor session 2 source vlan 100
monitor session 2 destination remote vlan 999
SW1
monitor session 1 source vlan 100
monitor session 1 destination remote vlan 999
monitor session 2 destination interface Fa0/19
monitor session 2 source remote vlan 999
According to Cisco doco you cannot have a SPAN and RSPAN on the same session, however since these are two sessions on SW1, I would have thought it to be OK.
Any thoughts on how to achieve this?
Cheers
Mike
5 Replies 5
nspasov
Hello Mike-
I had ran into this issue before where I needed the voice traffic captured and sent to a call-recording server. Unfortunately, the setup is not supported on the switch that you are using. You can only accomplish this on some of the higher end switches such as the Cat6500. You will either have to get a better/more expensive switch or if this is for call recording see if they call recording solution along with you PBX would support SIP call-forking
Here is a snip-it directly from the config guide for 2960s
The switch does not support a combination of local SPAN and RSPAN in a single session. That is,
an RSPAN source session cannot have a local destination port, an RSPAN destination session cannot
have a local source port, and an RSPAN destination session and an RSPAN source session that are
using the same RSPAN VLAN cannot run on the same switch stack
Thank you for rating!
Thank you for rating helpful posts!
I have the same problem, but I'm doing it on a Catalyst 4500 switch, is this switch compatible with this configuration?, because I can not see the traffic on the same switch.
yixiu0317
Level 3
Level 3
Did the destination port configured as access port?
Yes the span port is an access port on vlan 999
That wording is so ambuguious, I am not a lawyer and feel I need to be to be sure of that statement
Back in the days I even had a TAC case opened on this because I could not get it to work on my 3750s in a remote office while it perfectly worked in the HQ where we used 6500s Nevertheless, please do let me know if you find a workaround as I would be interested to know
