Showing results forĀ
Search instead forĀ
Did you mean:Ā
Secure Shell Protocols
Thembinkosi
Visitor
I have assigned a switch a User name and set a password. Line vty is enabled using ssh. I am trying to check my ssh for the switch but it says connection has timed out. What do i do to fix this problem
Bryson F
Level 4
Level 4
Things to check for your switch.
1.is the switch pingable
2.did you create crypto keys for ssh? ie: switch(config)#crypto key generate rsa label ssh modulus 2048
3. on your line vty 0-4 or 0-15 did you do transport input ssh and transport output ssh
it would help if you gave us a "show run | b line" as well
IP_Cartel
Level 6
Level 6
post the config
How do I do that?
@ßāmůęļŕõbìþ
Bryson F
Level 4
Level 4
