05-29-2019 05:53 AM
I want to send device hostname in trap message. Right now hostname column shows IP address. I want it to reflect device hostname. I tried "logging origin-id hostname" but it did not work. I also tried "logging origin-id string SWITCH1" but no luck
I am having 3650 and running 16.6.5 code.
Below is the show run | in logging output
logging buffered 10000000
no logging console
no logging monitor
hw-switch switch 1 logging onboard message
logging host X.X.X.X transport udp port 1000
logging host X.X.X.X transport udp port 10514
logging host X.X.X.X transport udp port 27514
Solved! Go to Solution.
06-10-2019 06:39 AM
Sorry, Balaji for the delayed response.
I added host entry on the Solarwinds server and then that name was reflecting in the DNS field of the node details.
And I am also getting the hostname in the SNMP trap email alert.
Thanks.
05-29-2019 12:22 PM
we have seen some old IOS send only IP address and i need to map the information inside syslog mapping host with IP to resolve.
can have your IOS version ?
06-10-2019 06:39 AM
Thanks.
06-22-2019 05:41 PM
Glad it was working, can you mark as post as solved, so the solution can be used for other community members.
06-22-2019 11:51 PM
The configuration seems correct and I am happy that you had resolved your issue.
01-25-2024 01:29 AM
Is this command is logging or snmp trap ?
