SFP compactability
Kevin100
Hai
Is it possible to connect GLC SX MM 1G  to a core with X2 10 G SR .
ALSO SFP 10 G SR to X2 10 G SR
Consider all multi mode.
InayathUlla Sharieff
Vijay,
Please find the compatibility matrix for the GLX :-
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Inayath
*Please rate if this is helpfull.
Dear All
Thanks for reply.
Is it possible to connect 4500x with sfp plus
10g. To x2 10 G on core.
Both multimode fiber
ain features of Cisco 10GBASE SFP+ modules include:
   Smallest 10G form factor
   Commercial temperature (0 to 70°C) only
   Supports 10GBASE Ethernet only
   Hot-swappable input/output device that plugs in to an Ethernet SFP+ port of Cisco platforms
   Provides flexibility of interface choice
   Supports digital optical monitoring capability
   Cisco quality identification (ID) feature that enables a Cisco platform to identify - optics supported by Cisco technology
   Optical interoperability with 10GBASE XENPAK, 10GBASE X2, and 10GBASE XFP interfaces on the same link
Mark Malone
Hi no you cannot interconnect these transceivers
