09-28-2022 04:15 AM
Hello everyone,
first of thank you all for your ideas and help beforehand.
Devices:
Situation:
I want to connect SW1 to SW3 via SFP fibre and SW2 to SW3 via SFP fibre; but the status stays Link down Protocol down.
Configuration:
=====SW3======| 15.2(7)E4 |=====| C2960X-UNIVERSALK9-M |=====
interface GigabitEthernet1/0/25
switchport trunk allowed vlan 3,9,18,81
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/26
=====SW2======| 15.2(7)E3 |=====| C2960X-UNIVERSALK9-M |=====
interface GigabitEthernet1/0/52
=====SW1======| 15.2(7)E3 |=====| C2960X-UNIVERSALK9-M |=====
What I tried so far:
Additonal information:
There are also cupper connections between the switches as trunks and running rstp; these connections working fine and with no issues.
So has anyone an idea why the SFP connections / interfaces are acting so weirdly? Or do I miss anything? I am sitting on that issue since two days now, searching the internet, trying out step by step configurations/test and i still can't wrap my mind around it.
Also if you need more information I would be glad to provide you with those.
Kind regards and take care all of you,
Gabor
Solved! Go to Solution.
10-05-2022 06:29 AM
Okay, I tried it and well it works. So thanks a lot ... even though I don't get it since I used the same setup of patching to run the connection between SW1 and SW2 for the test, there it worked with no issues.
10-05-2022 06:33 AM
I've seen patch panels where some links are straight through and others crossed - very confusing and usually the first thing I check when there is no link up on a given pair
Andy
10-05-2022 06:48 AM
Well I will do that from now on as well, thats for sure.
Thanks again and have a nice one.
Gabor
10-05-2022 05:14 AM
A different thought I have, could it be possible that the ISO can be an issue? Since 15.2(7)E3 is running on SW1/SW2 and 15.2(7)E4 on SW3... on the IOS side I am kinda lost so could anyone of you provide me an answer if that is an possible issue? On the internet I don't find much other than the IOS realse notes which doesn't cover any SFP bugs, so far I can tell.
