SFP Module cisco 3750 Switch
mahesh-gohil
Dear all,
I had cisco 3750 switch
and sfp module inserted is GLC-SX-MM but as I am not able to detect it via show inventory.
Pl. guide
regards
mhaesh
8 Replies 8
spremkumar
Level 9
Level 9
Are you using Third party SFP modules or Cisco make ?
also are you seeing any error logs on your switch ?
if possible do post the output of show version and show inventory here..
regds
ya i am using cisco made sfp module and sh inventory and sh ver attached for your reference
do reply
it's urgent
regards
mahesh
hi
did u try swapping the sfp in some other chassis ?
regds
spremkumar
Level 9
Level 9
regds
sorry but i have no other chassis
I have two sfp module and tried with change it to other port with same chassis
regards
mahesh
I wonder nobody is there to reply
Mahesh
Mahesh,
I have come across a lots of cased like this where there is not solution to the problem that you are facing. This is directly related to the lack of featureset in the IOS. I have come across a bug which lists the same symptom. This may not be directly link to your case but its one problem that can be linked:
CSCei33920
Output of sho inventory does not display certain SFPs:
HTH,
-amit singh
d-mark
when inserted the SFP module in one port take a look at the output of "show interface gigabitethernetX/Y" watch for a line (I think it is line 5) including the word "media", there should be a short description of the SFP. Also look at the first line of "show interface gigabitethernetX/Y" it could be that the SFP doesn't work in the switch (maybe because it is a none cisco one) then there would be something like "err-disabled". And if you have logging enabled on the switch (e.g. logging buffered 8192 debugging) then there should be an error message also.
The command "show idprom interface gigabitethernetX/Y" shows information about the SFP module in slotX/Y.
regards
Mark
