SG500 VLAN inter vlan routing
jdurrence
We are installing a Mitel VoIP system.  The switch is in layer 3 mode.   My data is currently on VLAN 1, untagged and PVID 1 (10.10.1.0/24).  In preparation for the new VoIP, I setup a VLAN 30.   It is VLAN 30, tagged (10.10.2.0/24).  The ports are in trunk mode, Voice VLAN is set to 30.  When I check a port it is listed as 1UP, 30T.  This works for the phones, but the routing between VLANs does not work.   I've setup the interfaces as 10.10.1.1 and 10.10.2.1.  From the SG500, it can ping both interfaces.  I can also ping both interfaces from a computer on either VLAN, but nothing beyond that.  I.E.   I have a laptop on VLAN 30 that can ping both VLAN interfaces but not ping a computer on VLAN 1.   Also, I can ping both interfaces from a computer on VLAN 1, but not the laptop on VLAN 30.  So thru my testing I have found if I change the port the laptop is on:
Vlan1 = excluded
Vlan30 = Untagged, PVID
I can ping the laptop from the computer on Vlan1
I can ping from the laptop to the VLan30 interface
Change it to:
Vlan1 = untagged, PVID
Vlan30 = tagged
I can no longer ping the laptop from the computer on Vlan1
I can no longer ping from the laptop to the Vlan30 interface.
I guess my question is that I've used VLANs before, but all traffic was untagged, just used different subnets and the SG500 could inter route just fine.  Now that one VLAN has untagged traffic (data) and the other VLAN has tagged traffic (Voice), the SG500 seems to not be able to route the traffic across the two VLANs.   The Mitel controller is on the VLAN 30 side and I need to use a web browser on the VLAN 1 side to http into the admin portal.   I'm not sure if this is the way tagged and untagged VLANs are suppose to work vs. multiple VLANs with all traffic untagged.   I need to be able to use QoS on the voice traffic, but I guess it doesn't have to be on another VLAN.   Just trying to follow best practice.
Any one have suggesstions.
8 Replies 8
Tom Watts
Hi Jdurrence, can you do a trace route from computer A in vlan 1 to computer B in vlan 2? This should complete with 1 hop.
Let me know the result (assuming you do not have firewalls on the computers blocking anything)
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
When I ping it, the first hop is from the VLAN1 interface, there is not a 2nd hop, but on line two, it says 10.10.1.1 reports:
destination host unreachable.
Hi J, Are you running 1.2.7.76 firmware?
Can you please post a snapshot of the configuration of the switch and also a snapshot of the configuration of both computers NIC?
The switch configuration should be something like
config t
vlan database
vlan 30
int vlan 1
ip address 192.168.1.254 /24
int vlan 30
ip address 192.168.2.254 /24
interface gi1/1/2
switchport mode access
switchport access vlan 30
Your computer NIC configuration should be something like
Computer A in Vlan 1 -
192.168.1.10
255.255.255.0
192.168.1.254
Computer B in Vlan 30 -
192.168.2.10
255.255.255.0
192.168.2.254
Also remember don't try to use host name, just use IP address for this purpose.
-Tom
The laptop is 192.168.2.254, 255.255.255.0, 192.168.2.1 for the gateway.  The desktop is 192.168.1.200, 255.255.255.0, 192.168.1.1 for the gateway.  Below is the running config.  I am running v1.2.7.76.
config-file-header
SG500
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 30
exit
voice vlan id 30
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
voice vlan oui-table add 08000f Mitel_phone
bonjour interface range vlan 1
hostname SG500
management access-list All-Access
permit ip-source 192.168.1.1 mask 255.255.255.0 vlan1
exit
management access-class All-Access
username cisco password encrypted fd955e6a81dejlwkje944102f69bcf21c0 privilege 15
ip ssh server
snmp-server location "Office"
clock timezone " " -5
clock summer-time web recurring usa
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 132.163.4.101 poll
ip name-server  4.2.2.2
ip telnet server
interface vlan 1
no ip address dhcp
interface vlan 30
name Voice
ip address 192.168.2.1 255.255.255.0
interface gigabitethernet1/1/1
shutdown
interface gigabitethernet1/1/2
interface gigabitethernet1/1/3
interface gigabitethernet1/1/4
interface gigabitethernet1/1/6
interface gigabitethernet1/1/7
interface gigabitethernet1/1/8
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
macro description "ip_phone_desktop "
!next command is internal.
macro auto smartport dynamic_type unknown
interface gigabitethernet1/1/9
interface gigabitethernet1/1/10
interface gigabitethernet1/1/11
interface gigabitethernet1/1/12
interface gigabitethernet1/1/13
interface gigabitethernet1/1/14
interface gigabitethernet1/1/15
interface gigabitethernet1/1/16
interface gigabitethernet1/1/17
interface gigabitethernet1/1/18
macro description ip_phone_desktop
interface gigabitethernet1/1/19
interface gigabitethernet1/1/20
interface gigabitethernet1/1/21
interface gigabitethernet1/1/22
interface gigabitethernet1/1/23
interface gigabitethernet1/1/24
switchport trunk allowed vlan add 30
interface gigabitethernet1/1/25
interface gigabitethernet1/1/26
interface gigabitethernet1/1/27
interface gigabitethernet1/1/28
interface gigabitethernet1/1/29
interface gigabitethernet1/1/30
interface gigabitethernet1/1/31
interface gigabitethernet1/1/32
interface gigabitethernet1/1/33
interface gigabitethernet1/1/34
spanning-tree link-type point-to-point
macro description switch
interface gigabitethernet1/1/35
interface gigabitethernet1/1/36
interface gigabitethernet1/1/37
interface gigabitethernet1/1/38
interface gigabitethernet1/1/39
interface gigabitethernet1/1/40
interface gigabitethernet1/1/41
interface gigabitethernet1/1/42
interface gigabitethernet1/1/43
interface gigabitethernet1/1/44
interface gigabitethernet1/1/45
interface gigabitethernet1/1/46
interface gigabitethernet1/1/47
interface gigabitethernet1/1/48
interface gigabitethernet1/1/49
interface gigabitethernet1/1/50
interface gigabitethernet2/1/1
interface gigabitethernet2/1/2
interface gigabitethernet2/1/3
interface gigabitethernet2/1/4
interface gigabitethernet2/1/5
interface gigabitethernet2/1/6
interface gigabitethernet2/1/7
interface gigabitethernet2/1/8
interface gigabitethernet2/1/9
interface gigabitethernet2/1/10
interface gigabitethernet2/1/11
interface gigabitethernet2/1/12
interface gigabitethernet2/1/13
interface gigabitethernet2/1/14
interface gigabitethernet2/1/15
interface gigabitethernet2/1/16
interface gigabitethernet2/1/17
interface gigabitethernet2/1/18
interface gigabitethernet2/1/19
interface gigabitethernet2/1/20
interface gigabitethernet2/1/21
interface gigabitethernet2/1/22
interface gigabitethernet2/1/23
interface gigabitethernet2/1/24
interface gigabitethernet2/1/25
interface gigabitethernet2/1/26
interface gigabitethernet2/1/27
interface gigabitethernet2/1/28
interface gigabitethernet2/1/29
interface gigabitethernet2/1/30
interface gigabitethernet2/1/31
interface gigabitethernet2/1/32
interface gigabitethernet2/1/33
interface gigabitethernet2/1/34
interface gigabitethernet2/1/35
interface gigabitethernet2/1/36
interface gigabitethernet2/1/37
interface gigabitethernet2/1/38
interface gigabitethernet2/1/39
interface gigabitethernet2/1/40
interface gigabitethernet2/1/41
interface gigabitethernet2/1/42
interface gigabitethernet2/1/43
interface gigabitethernet2/1/44
interface gigabitethernet2/1/45
interface gigabitethernet2/1/46
interface gigabitethernet2/1/47
interface gigabitethernet2/1/48
interface gigabitethernet2/1/49
interface gigabitethernet2/1/50
interface gigabitethernet3/1/1
interface gigabitethernet3/1/2
interface gigabitethernet3/1/3
interface gigabitethernet3/1/4
interface gigabitethernet3/1/5
interface gigabitethernet3/1/6
interface gigabitethernet3/1/7
interface gigabitethernet3/1/8
interface gigabitethernet3/1/9
interface gigabitethernet3/1/10
interface gigabitethernet3/1/11
interface gigabitethernet3/1/12
interface gigabitethernet3/1/13
interface gigabitethernet3/1/14
interface gigabitethernet3/1/15
interface gigabitethernet3/1/16
interface gigabitethernet3/1/17
interface gigabitethernet3/1/18
interface gigabitethernet3/1/19
interface gigabitethernet3/1/20
interface gigabitethernet3/1/21
interface gigabitethernet3/1/22
interface gigabitethernet3/1/23
interface gigabitethernet3/1/24
interface gigabitethernet3/1/25
interface gigabitethernet3/1/26
interface gigabitethernet3/1/27
interface gigabitethernet3/1/28
interface gigabitethernet3/1/29
interface gigabitethernet3/1/30
interface gigabitethernet3/1/31
interface gigabitethernet3/1/32
interface gigabitethernet3/1/33
interface gigabitethernet3/1/34
interface gigabitethernet3/1/35
interface gigabitethernet3/1/36
interface gigabitethernet3/1/37
interface gigabitethernet3/1/38
interface gigabitethernet3/1/39
interface gigabitethernet3/1/40
interface gigabitethernet3/1/41
interface gigabitethernet3/1/42
interface gigabitethernet3/1/43
interface gigabitethernet3/1/44
interface gigabitethernet3/1/45
interface gigabitethernet3/1/46
interface gigabitethernet3/1/47
interface gigabitethernet3/1/48
interface gigabitethernet3/1/49
interface gigabitethernet3/1/50
no macro auto processing cdp
macro auto processing type ap disabled
ip route 0.0.0.0 0.0.0.0 172.20.9.254
Hi J, unless I missed it, I do not see any port set to vlan 30.
All ports read switchport mode access or a macro port.
When using the voice vlan, the data vlan is untagged, voice vlan is tagged. The native vlan will still remain 1.
The way it seems to me you basically have 2 computers in vlan 1 with different network IP.
Can you verify one port is set up as vlan 30 native then connect the respective computer?
int gi1/1/10
-Tom
I finally got this fixed.   I'm still not 100% sure why it didn't work before, but this was all for a Mitel VoIP system.  The installer had not been setting the phones to use VLAN30.  Once I changed that on each phone and made the ports trunks, vlan1 untagged, and vlan 30 tagged, it all started routing and letting me ping.  Thanks so much for the help Tom!
Mike Hogenauer
Hi J,
I'm having the same issue and it's driving me MAD! I have almost your exact same config. I've have the VLAN1 as the default
And I’ve created Vlan 2 for Voice and we’re installing Mitel phones. Problem is that I can’t ping ant device even the Layer 3 interface of the VoIP VLAN. Did just telling the phones to Tag for the Voice VLAN solve it? I’ve left all ports as trunks and daisy chained the PC’s off the back of the phones.  Any help would be greatly appreciated.
Telling the phones to tag the traffic solved like 90% of my problems.  Go on the config on the phones and verify that it is using your vlan 2.  My setup was saying vlan none.  If you need to change it on the phone,  it is under the L2 settings.  Also on any port that had a phone,  make sure it is set as a trunk.  Then under port to vlan,  make it be vlan 1 untagged, and vlan 2 tagged.  Also on the trunk port settings for the port that has the mitel switch plugged in it,  set it to vlan 2 as pvid and untagged.  Hope this helps,  let me know.
