SGE2000 Management IP
king.c.david
I've recently inhierited a network which relies on a couple of SGE2000 network which has multiple vlans configured, unfortunatley i am unable to get to the management ip of the device to look at the config. I have put in a serial cable it see that the management IP is 192.168.1.254 on vlan 1, but when i plug a device into the swithc and give it a IP on that range (both untagged and vlan 1 tagged) it is unable to access the MGMT IP.
anyone got any advice on where i have gone wrong??
dave
52 Replies 52
cadet alain
Hi dave,
but when i plug a device into the switch and give it a IP on that range (both untagged and vlan 1 tagged) it is unable to access the MGMT IP.
VLAN 1 is not tagged by default.
What do you mean, you can't ping that address? or you can't telnet/ssh to it?
Regards.
Alain.
Hi Cadetalain
I am unable to access telnet, SSH, or use http or https to get to the config of the switch
using the network Configuration ping utility from the serial console it is unable to ping the machine which i have attached to the switch.
I'm sure i'm missing something simple, but not sure what
Dave
(the switch is in layer 2 mode, should this make a difference?)
n.b. this is the result of a tracert from the swith
                               TraceRoute IPv4
IP Address:
192.168.1.10
Status:      Tracing the route to 192.168.1.10 , 30 hops max, 40 byte packets
              Trace complete.
Results:     Net unreachable.
First is int VLAN up|up? ---> show ip int br | in Vlan
Second is the port where machine is connected in the same VLAN ? ---->  sh int XX switchport where XX is interface id of port connecting to machine.
Post results here  so we can see which further commands could help resolve the problem.
Regards.
Alain.
Hi Alain
Well this seem to be the issue, i don't have proper CLI access though the serial, only this strange switch menu, so i can't see which ports are tagged with what vlan. (see attached screenshot)
The switch has multiple vlans on there, but in this simple menu system it is only showing the default vlan (see another screenshot)
So i'm a little lost on where to go
Dave
On your machine is the switch appearing in the arp cache? ----> arp -a
Regards.
Alain.
Hi Alain
no arp for that IP
Interface: 192.168.1.10 --- 0xa
  Internet Address      Physical Address      Type
  192.168.1.255         ff-ff-ff-ff-ff-ff     static
  224.0.0.22            01-00-5e-00-00-16     static
  224.0.0.252           01-00-5e-00-00-fc     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
also i get no recieved packets on that NIC either
Dave
Can you post ipconfig/all, route print and the failing ping to the switch IP
On which OS are you, if Windows 7 or vista what is your network profile for the NIC: public or private? if private change it to public and retry
Regards.
Alain.
Hi Alain it's running Server 2008 ipc
C:\Users\Administrator.MORETON>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : moreton-dom04
   Primary Dns Suffix  . . . . . . . : moreton.local
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : moreton.local
Ethernet adapter 254:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : HP NC107i PCIe Gigabit Server Adapter #2
   Physical Address. . . . . . . . . : 1C-C1-DE-80-23-F1
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.254.198(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.254.254
   DNS Servers . . . . . . . . . . . : 192.168.254.2
                                       192.168.254.5
                                       192.168.254.198
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Cisco MGMT:
   Physical Address. . . . . . . . . : 1C-C1-DE-80-23-F0
   IPv4 Address. . . . . . . . . . . : 192.168.1.10(Preferred)
Tunnel adapter Local Area Connection* 8:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : isatap.{78D507B5-C7FB-4752-B2F3-6906F2672
93A}
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : isatap.{1D2D8A62-C9F8-4FDA-82FA-88C31444D
E04}
Tunnel adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 13:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter Local Area Connection* 14:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
C:\Users\Administrator.MORETON>route print
Interface List
11 ...1c c1 de 80 23 f1 ...... HP NC107i PCIe Gigabit Server Adapter #2
10 ...1c c1 de 80 23 f0 ...... HP NC107i PCIe Gigabit Server Adapter
  1 ........................... Software Loopback Interface 1
12 ...00 00 00 00 00 00 00 e0  isatap.{78D507B5-C7FB-4752-B2F3-6906F267293A}
13 ...00 00 00 00 00 00 00 e0  isatap.{1D2D8A62-C9F8-4FDA-82FA-88C31444DE04}
19 ...00 00 00 00 00 00 00 e0  Microsoft ISATAP Adapter #3
20 ...00 00 00 00 00 00 00 e0  Microsoft ISATAP Adapter #4
21 ...00 00 00 00 00 00 00 e0  Microsoft ISATAP Adapter #5
22 ...00 00 00 00 00 00 00 e0  Microsoft ISATAP Adapter #6
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0  192.168.254.254  192.168.254.198    276
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      192.168.1.0    255.255.255.0         On-link      192.168.1.10    266
     192.168.1.10  255.255.255.255         On-link      192.168.1.10    266
    192.168.1.255  255.255.255.255         On-link      192.168.1.10    266
    192.168.254.0    255.255.255.0         On-link   192.168.254.198    276
  192.168.254.198  255.255.255.255         On-link   192.168.254.198    276
  192.168.254.255  255.255.255.255         On-link   192.168.254.198    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link   192.168.254.198    276
        224.0.0.0        240.0.0.0         On-link      192.168.1.10    266
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link   192.168.254.198    276
  255.255.255.255  255.255.255.255         On-link      192.168.1.10    266
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
          0.0.0.0          0.0.0.0  192.168.254.254  Default
IPv6 Route Table
Active Routes:
If Metric Network Destination      Gateway
  1    306 ::1/128                  On-link
  1    306 ff00::/8                 On-link
Persistent Routes:
  None
C:\Users\Administrator.MORETON>ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.10: Destination host unreachable.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.254:
    Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Dave
Request timed out.
Request timed out.
Request timed out.
What is the arp cache saying now?
Can you disable firewall and try again.
Regards.
Alain.
still saying nothing
C:\Users\Administrator.MORETON>arp -a
Interface: 192.168.254.198 --- 0xb
  192.168.254.1         00-1a-4b-ca-5d-e5     dynamic
  192.168.254.2         00-18-8b-38-e0-17     dynamic
  192.168.254.3         00-11-43-e0-96-f2     dynamic
  192.168.254.4         00-18-8b-e5-62-f9     dynamic
  192.168.254.5         00-22-19-7a-33-8a     dynamic
  192.168.254.17        00-0d-56-fd-4d-19     dynamic
  192.168.254.26        00-1e-c9-da-6d-94     dynamic
  192.168.254.27        00-1a-a0-02-a9-a3     dynamic
  192.168.254.33        00-23-ae-87-0e-51     dynamic
  192.168.254.38        00-21-5a-60-01-46     dynamic
  192.168.254.41        00-23-ae-7c-b1-a7     dynamic
  192.168.254.43        00-19-db-bf-63-44     dynamic
  192.168.254.46        00-23-ae-5c-06-f1     dynamic
  192.168.254.47        00-21-5a-59-aa-06     dynamic
  192.168.254.48        00-19-d1-29-5e-06     dynamic
  192.168.254.49        00-23-ae-8b-43-79     dynamic
  192.168.254.50        00-13-20-6b-d4-23     dynamic
  192.168.254.51        00-08-74-b7-2d-05     dynamic
  192.168.254.52        00-1c-c4-1f-d1-78     dynamic
  192.168.254.55        00-19-db-bf-63-8b     dynamic
  192.168.254.58        00-0f-1f-51-9f-50     dynamic
  192.168.254.63        00-1a-4b-ca-60-f8     dynamic
  192.168.254.67        00-16-76-cb-f5-3c     dynamic
  192.168.254.71        00-13-20-a9-a8-ec     dynamic
  192.168.254.76        00-0f-1f-67-77-17     dynamic
  192.168.254.81        00-1b-78-81-b3-a4     dynamic
  192.168.254.82        00-17-a4-14-90-bf     dynamic
  192.168.254.122       00-01-6c-91-63-55     dynamic
  192.168.254.132       00-1a-4b-ca-5e-36     dynamic
  192.168.254.137       00-1b-78-82-7a-43     dynamic
  192.168.254.138       00-1b-78-82-77-e9     dynamic
  192.168.254.139       00-1b-78-a6-8a-47     dynamic
  192.168.254.140       0e-d5-d2-ea-7b-1c     dynamic
  192.168.254.143       00-17-a4-16-fd-be     dynamic
  192.168.254.144       1c-c1-de-80-23-cd     dynamic
  192.168.254.146       00-23-ae-89-18-d9     dynamic
  192.168.254.147       e6-f7-82-93-a9-a5     dynamic
  192.168.254.148       00-1b-78-81-ba-9f     dynamic
  192.168.254.149       00-19-d1-6b-0e-75     dynamic
  192.168.254.150       b6-89-d7-b6-11-71     dynamic
  192.168.254.151       00-16-17-5c-c1-79     dynamic
  192.168.254.152       3a-64-2b-69-19-9d     dynamic
  192.168.254.153       16-a3-f2-d8-37-7f     dynamic
  192.168.254.154       00-23-ae-7e-e7-8c     dynamic
  192.168.254.155       00-1a-4b-ca-61-83     dynamic
  192.168.254.156       26-9a-7b-57-61-6b     dynamic
  192.168.254.157       00-1b-78-81-ba-70     dynamic
  192.168.254.158       00-19-db-bf-62-e9     dynamic
  192.168.254.159       00-23-ae-5b-fc-cc     dynamic
  192.168.254.160       c6-58-d0-84-ae-74     dynamic
  192.168.254.161       00-23-ae-5b-fc-9a     dynamic
  192.168.254.164       00-23-ae-8b-50-aa     dynamic
  192.168.254.165       c2-08-ef-79-53-c8     dynamic
  192.168.254.166       66-11-9e-90-38-66     dynamic
  192.168.254.167       c6-41-eb-dc-68-45     dynamic
  192.168.254.168       00-25-b3-eb-ba-93     dynamic
  192.168.254.169       52-a5-9a-3f-34-df     dynamic
  192.168.254.171       00-1a-4b-ca-5e-b7     dynamic
  192.168.254.172       00-19-d1-29-a4-91     dynamic
  192.168.254.174       00-0b-db-0f-d1-02     dynamic
  192.168.254.175       00-1b-78-c2-f3-50     dynamic
  192.168.254.176       00-21-85-32-d3-43     dynamic
  192.168.254.178       00-1b-38-3e-1d-86     dynamic
  192.168.254.179       00-1a-4b-cc-43-5b     dynamic
  192.168.254.180       00-08-74-b7-54-95     dynamic
  192.168.254.181       00-1a-4b-ca-5d-40     dynamic
  192.168.254.182       00-13-20-ad-4b-b1     dynamic
  192.168.254.183       00-1b-78-81-bd-24     dynamic
  192.168.254.184       00-13-20-c1-e0-54     dynamic
  192.168.254.185       00-23-ae-7a-eb-89     dynamic
  192.168.254.187       00-23-ae-7a-eb-41     dynamic
  192.168.254.188       00-17-a4-16-c2-f3     dynamic
  192.168.254.189       00-0b-db-0d-dd-53     dynamic
  192.168.254.190       00-1b-78-81-ba-84     dynamic
  192.168.254.191       00-0b-db-0e-f0-28     dynamic
  192.168.254.192       00-1b-78-82-77-8a     dynamic
  192.168.254.194       00-1b-78-c2-e4-87     dynamic
  192.168.254.195       60-eb-69-55-4e-e0     dynamic
  192.168.254.196       00-1a-4b-ca-5d-3f     dynamic
  192.168.254.197       00-23-ae-7e-f9-48     dynamic
  192.168.254.212       d8-d3-85-db-31-18     dynamic
  192.168.254.214       16-eb-e9-9e-06-7b     dynamic
  192.168.254.215       42-e7-67-e6-ea-54     dynamic
  192.168.254.221       7e-db-5b-62-60-4c     dynamic
  192.168.254.224       2a-b2-39-b0-a5-6e     dynamic
  192.168.254.226       8a-ec-8f-7e-80-04     dynamic
  192.168.254.227       c2-11-1f-bb-e1-24     dynamic
  192.168.254.229       aa-ef-3c-3a-94-ae     dynamic
  192.168.254.232       00-23-ae-7a-e8-7a     dynamic
  192.168.254.233       1c-c1-de-f2-32-15     dynamic
  192.168.254.234       00-0d-87-f2-f9-c6     dynamic
  192.168.254.235       00-1a-4b-ca-5f-c2     dynamic
  192.168.254.236       00-1a-4b-ca-5f-c9     dynamic
  192.168.254.237       00-1b-78-b3-e5-30     dynamic
  192.168.254.239       00-23-ae-7a-eb-96     dynamic
  192.168.254.254       00-00-5e-00-01-04     dynamic
  192.168.254.255       ff-ff-ff-ff-ff-ff     static
firewall is already disabled on this machine
Dave
Hi Dave,
Have you looked at the port configuration screen from the main menu, and made sure that the port you are trying to access the switch is in VLAN 1.
The screen you are getting is the only screen you get via the console cable.
I can't remeber all the steps need but could get one that I have in our stores and talk you through it.
Hi Ronnie
The port config menu doesn't show any details for vlans, just the flow control, speed/duplex , auto negociate and enable and disable. Please see screenshot
The port i am connected to (6) is enabled and is showing as a GIG connection on my attached device (again see attached screenshot)
normally i would reboot the router and then reset, but as it's integral to a network which can't have down time (this will change when i get access!) i'm unable to do this
Dave
give me 10 mins and I will get the one out of my stores and fire it up and give you the steps.
That option is not in the system, what you could try is to do a backup of the config via TFTP you will then be able to see what IP you have.
Another question is the system mode in layer 3 if it is you could try the IP address of your default gateway.
