show policy-map interface question (QoS)
mats.brynolf
The counters are at 0 when I run show policy-map interface vlan 133 on a 3560 (desktop default). I have verified with Whireshark that the packets get rewritten to DSCP 24. So the question is why does it say 0 with the show command. I've done exactly the same on a 6509 and there I can see the counters changing.
C3560#show policy-map interface vlan 133
Vlan133
Service-policy input: test
Class-map: test (match-any)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group name test
0 packets, 0 bytes
rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
class-map match-any test
match access-group name test
policy-map test
class test
set dscp 24
interface GigabitEthernet0/14
switchport access vlan 133
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos vlan-based
spanning-tree portfast
interface Vlan133
no ip address
service-policy input test
ip access-list standard test
permit any
This has been discussed many times on here and is a limitation of the platform (same for almost all the fixed configuration Catalysts). The simple answer is the counters don't work and there is no tweak you can perform to make them work. The only command that shows you any half-useful statistics is 'show mls qos interface statistics'. This will show you counters for the incoming & outgoing DSCP & CoS values, plus two counters for 'Inprofile' and 'Outprofile'. These last two counters show you what traffic has adhered to its configured bandwidth within a policy and what hasn't. It doesn't show you individual counters for each class, nor does it show you whether the action was to drop or mark-down.
The older Catalyst 3550 had much better counters available with the same command, however the 'show policy-map interface' command didn't work on this platform either.
Andy
mats.brynolf
I just found this to answer my own question above:
The show policy-map interface command is not supported on 3750 and 3560 switches, even though it is allowed to be typed in the CLI.
http://supportwiki.cisco.com/ViewWiki/index.php/Unable_to_display_QoS_information_at_the_port_level_with_the_show_policy-map_interface_command_in_Catalyst_3750_switch
Andy
Snippet from CiscoLive 2016 presentation reitterating this point.
Does anyone know if/What platform the Cisco IE-2000 is based/architected?  2960/3650 I suspect.
It suffers the same problem.  It is fixed in the IE-3x00 finally it seems.
