Slow file copy to a Nexus 93180YC-EX
Network Diver
Level 3
Level 3
We have four Nexus 93180YC-EX running NXOS 7.0(3)I4(6) and an uptime of > 2100 days. I need to update them to the latest recommended NXOS version.
Management interface is a VLAN interface. The dedicated management interface is used for vPC peer keep-alive.
Copying a software image of circa 950 MB size takes about 2 hours, no matter whether I copy it via HTTP or SCP or SFTP from a host in the same datacenter. Another copy did not finish after 12 hours. We have a bunch of newer Nexus switches that came with NXOS 9.3.x and there same copy was much faster.
nexus9k# copy http://1.2.3.4/cisco/nexus/93180YC-EX/nxos.7.0.3.I7.10.bin bootflash:
Enter vrf (If no input, current vrf 'default' is considered):
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
 16  940M   16  151M    0     0   136k      0  1:57:23  0:18:57  1:38:26  105k
Is it a software bug or due to the long uptime?
Bernd
marce1000
                   - FYIhttps://bst.cisco.com/bugsearch/bug/CSCvh45935
 M.
7 Replies 7
marce1000
 M.
Network Diver
Level 3
Level 3
Thanks. With NXOS NXOS 7.0(3)I4(6) the default copp policy is:
nexus9k# show run all | section copp-system-p-policy-strict
policy-map type control-plane copp-system-p-policy-strict
  class copp-system-p-class-l3uc-data
    set cos 1
    police cir 800 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-critical
    set cos 7
    police cir 36000 kbps bc 1280000 bytes conform transmit violate drop
  class copp-system-p-class-important
    set cos 6
    police cir 2500 kbps bc 1280000 bytes conform transmit violate drop
  class copp-system-p-class-openflow
    set cos 5
    police cir 1000 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-multicast-router
    set cos 6
    police cir 2600 kbps bc 128000 bytes conform transmit violate drop
  class copp-system-p-class-multicast-host
    set cos 1
    police cir 1000 kbps bc 128000 bytes conform transmit violate drop
  class copp-system-p-class-l3mc-data
    set cos 1
    police cir 2400 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-normal
    set cos 1
    police cir 1400 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-ndp
    set cos 6
  class copp-system-p-class-normal-dhcp
    set cos 1
    police cir 1300 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-normal-dhcp-relay-response
    set cos 1
    police cir 1500 kbps bc 64000 bytes conform transmit violate drop
  class copp-system-p-class-normal-igmp
    set cos 3
    police cir 3000 kbps bc 64000 bytes conform transmit violate drop
  class copp-system-p-class-redirect
    set cos 1
    police cir 280 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-exception
    set cos 1
    police cir 150 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-exception-diag
    set cos 1
  class copp-system-p-class-management
    set cos 2
    police cir 10000 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-monitoring
    set cos 1
    police cir 150 kbps bc 128000 bytes conform transmit violate drop
  class copp-system-p-class-l2-unpoliced
    set cos 7
    police cir 50 mbps bc 8192000 bytes conform transmit violate drop
  class copp-system-p-class-undesirable
    set cos 0
    police cir 200 kbps bc 32000 bytes conform transmit violate drop
  class copp-system-p-class-fcoe
    set cos 6
    police cir 1060 kbps bc 128000 bytes conform transmit violate drop
  class copp-system-p-class-nat-flow
    set cos 7
    police cir 800 kbps bc 64000 bytes conform transmit violate drop
  class copp-system-p-class-l2-default
    set cos 0
    police cir 400 kbps bc 32000 bytes conform transmit violate drop
  class class-default
    set cos 0
  service-policy input copp-system-p-policy-strict
 The planned recommended upgrade path is NXOS 7.0(3)I4(6) → 7.0(3)I7(3) → 7.0(3)I7(10) → 9.3(11) → 10.2(4)M. From the bug description this is fixed in 7.0(3)I7(3).
Petr Jaros
I have similar issue, but policy values seems to be corrected, in compare with bug description. We have NX-OS 9.3(7).
set cos 2
police cir 36000 kbps bc 512000 bytes conform transmit violate drop
SCP transfer starts at 2MB/s, then after few seconds drop to ~60KB/s. Upload image take ages with this speed. Source (windows server) and destination (switch) are in same subnet.
dgaunt
You can use the “use-kstack” syntax with the copy command on the nexus switches to increase the speed of the copy commands.  See attached documentation for details.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/progammability/guide/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x_chapter_0101100.html#id_105304
@dgaunt did you note in OP:  ". . . I copy it via HTTP or SCP or SFTP from a host in the same datacenter."
and in your reference:  "This option can be beneficial when copying files from remote servers that are multiple hops from the switch."
So, might not make much of a difference in OP's case.
Also, unclear whether the alternative network stack would bypass CoPP, or the noted bug, again, might not make a difference.
That said, should be easy enough to try, and I suspect, unlikely to do worst or have other adverse effect.
thatgeekinit
I'm having this problem too on four N9K-C9336C-FX2 running 10.2.6M via the mg0 port on the management vrf. The file transfers seem to be capped at ~320KB/s per switch. If I run two switches at once, they both hit around 320KB/s so its not any other limiter along the way that I can see.
I've tried http and sftp. It's not a local server but its connected via 1gbps w 1gpbs switching and into a 10gbps internet connection that no one else is using.
If the actual file transfer is via the management port, the port might be the issue.  Sometimes such ports are not hardware supported like the data ports.
