Spanning Tree Issue
William Ryan
Community Member
I have Vlan 198, that works for some users and not for others. This Vlan on a 2811 Router, connected to a 6509 (Router 1) via port Gi8/1. I feel part of the issue in that Router 1 should be the root and not Router 2. I have tried to making router 1 the Root using "spanning-tree vlan 198 root primary.
Any assistance is greatly appreciated...
Router 1
spanning-tree vlan 1,4-7,12,16-17,57-58,128,130-131,198-199,261 priority 4096
VLAN0198
  Spanning tree enabled protocol ieee
  Root ID    Priority    4294
             Address     0025.b4ce.cb40
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    4294   (priority 4096 sys-id-ext 198)
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Gi3/4               Desg FWD 4         128.260  P2p
Gi3/6               Desg FWD 4         128.262  P2p
Gi3/7               Desg FWD 4         128.263  P2p
Gi7/47              Desg FWD 4         128.815  P2p
Gi8/1               Desg FWD 4         128.897  P2p
Po1                 Desg FWD 1         128.1665 P2p
Router 2
spanning-tree vlan 1,7,12,16,57-58,128,130-131,197-199,263,300 priority 8192
VLAN0198
             Cost        1
             Port        1665 (Port-channel1)
  Bridge ID  Priority    8390   (priority 8192 sys-id-ext 198)
             Address     0025.b4ce.d700
             Aging Time 300
Po1                 Root FWD 1         128.1665 P2p
Po23                Desg FWD 3         128.1670 P2p
11 Replies 11
Aaron Harrison
Setting the root can optimise your topology, but not normally resolve connectivity issues. You have succesfully made R1 the root.
Can you detail your topology, i.e. what is connected to what, and where the VLAN is not working?
Maybe post your configs as well.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Drawing is a little simple, but the users on R2 can't use the Vlan. However users connected to R1 can.
VLAN 198 looks OK on R2; in that it can see that R1 is the root bridge.
It looks like only po1/po23 are active in the VLAN - have you configured the ports as access ports in VLAN198?
What cards/hardware/config is on R2?
Aaron
interface Port-channel1
 switchport
 switchport trunk native vlan 998
 switchport trunk allowed vlan 2-4094
 switchport mode trunk
 logging event trunk-status
 logging event bundle-status
 mls qos trust dscp
interface Port-channel23
 switchport
 switchport trunk allowed vlan 4,16,129,130,154,198,282,285,302,404
 switchport nonegotiate
 logging event link-status
 mls qos trust dscp
Hello
When you say it work for others can you elaborate- On the same switch or both switch or just on of them?
Also do these switches have vlans defined in there vtp database assuming they are cisco switches?
res
Paul
Kind Regards
Paul
Users connect to R1 have no issues, some users on R2 can connect using Vlan 198. The vlan is defined in the vtp database located on R1. R2 is a client.
Hello
So can you confirm
- The vlans is populated in either switch?
- Po1 is between the rtrs
- P23 is between each rtr and switch
lastly have you made any changes to the physical interfaces for the portchannels
I can also see the native vlan not being allowed over the P23
sh etherchannel summary
sh int trunk
Also post  the physical interfaces of each etherchannel.
res
Paul
Kind Regards
Paul
William Ryan
Community Member
Vlans are populated. Po1 connects R1 and R2. Po23 connects switch to R2.
#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 8
Number of aggregators:           8
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Te1/1(P)       Te2/1(P)
2      Po2(SU)         LACP      Te1/2(P)       Te2/2(D)
3      Po3(SU)         LACP      Te1/3(P)       Te2/3(D)
4      Po4(SD)         LACP      Te2/4(D)
10     Po10(SU)        LACP      Gi7/46(P)      Gi8/46(P)
22     Po22(RD)         -
23     Po23(SU)        LACP      Gi3/7(P)       Gi4/7(P)
24     Po24(SU)        LACP      Gi3/8(P)       Gi4/8(P)
interface GigabitEthernet3/7
 description
 switchport
 udld port aggressive
 mls qos trust dscp
 channel-group 23 mode active
end
interface GigabitEthernet4/7
 description
 switchport
 mls qos trust dscp
end
Port                Mode         Encapsulation  Status        Native vlan
Po1                 on           802.1q         trunking      998
Po23                on           802.1q         trunking      998
Port                Vlans allowed and active in management domain
Po23                4,16,129-130,154,198,282,285,302,404
Port                Vlans in spanning tree forwarding state and not pruned
Po1                 2-7,12,15-18,20,22,24,32-33,44,46,48,56-58,72-80,96-109,128-131,135-136,138-144,146,148,152-167,194-195,197-199,205-208,212-214,231,244,256-257,260-281,293-309,340,401-407,409-412,464-466,495,528,560-564,592,624-625,656-658,662-666,668-671,673-678,682-688,998-999
Hello
The physical interfaces of PC23  don't look the same as its L2 PC.23 - Did you manually create this portchannel?
What connects to these PC's? and its here where the users who are having issue reside  and is so just PC23  or others
res
Paul
Kind Regards
Paul
The port-channel was created after the physical interfaces. It's just user computers that are connected to the switch that uses po23.
Hello
So you have another switch connected to switch 2 via pc23?
I am assuming this is a cisco switch also and is also acting as a host switch with man IP and D/G
Can you try re-creating the port--channels between these two switches and allow the native vlan across the trunk
1) delete the old PC and default physical interfaces and shut them down (if possible)
2) configure port-channel in physical interfaces
-- port-channel will be created automatically
3)create trunking encapsulation or access port mode directly in port-channel interface (NOT on the physical interfaces)
4)enable physical interfaces "no shut"
res
Paul
Kind Regards
Paul
