Stack 3750 Modular Switch
JohnJudi
Level 2
Level 2
Hi friends!
I have a cisco c3750x-48pf-s switch. I want to buy another switch with same part number to have stack between these switches.
should these switches have same modular uplink to form stack?
can I have C3KX-NM-1G in one switch but no uplink module on another switch?
thanks in advance
reccon
Level 3
Level 3
Yes, you can have different modules in each switch of the stack - C3KX-NM-1G, C3KX-NM-10G or none
 This switch model comes with StackWise
Port and the stack is done using specific stack cable.
 New Switches like 9500 supports stackwise virtual and allow stack using uplinks
reccon
Level 3
Level 3
Deepak Kumar
this switch can be stackable in your condition but it is end of life in 2016 and end of support in 31-Oct-2021. It is hard to find out. Recommended to go with newer series.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
