Stack-power 3750x : FRU Power Supply is not responding
jsimons
After stacking two 3750X switches, with four equal power-supply's, with StackWise and PowerStack
, still got the next message every few hours
%PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
( note that the message revers to the second switch in the stack )
although the stackwise and powerstack on the switches is oke and are working correctly. !
Config  : Stack-power in power-sharing mode/strict
With CLI on the switch : All the power supply's and stack-power details, prio look OK.
Only:
LMS prime /inventory/cisco-view/configure/power supply status
result :  some power supply's are marked as disabled.
with the command  > power supply 2 slot a off/on I manage
to get the status back to "normal", but after a few hours
some power supply's are again marked as "disabled".
Looks like SNMP en IOS difference from opinion.
Has somebody got the same experience ?
Hardware
WS-C3750X-24S-S
C3KX-PWR-350WAC
Software
15.0(2)SE
C3750E-UNIVERSALK9-M
9 Replies 9
MISAdminVAK
Hi There,
I am noticing this also, every 2 hours however I'm not using redundant power supply's.
I have the same IOS version running on my WS-C3750X-48T-S stacked pair.
The only thing is I have just unboxed them and they are on my desk running through power extension bars.
I am going to rack them today and will monitor the situation as they will be on UPS.
The switches are working fine even when the event is triggered.
I let you know if there is any change.
 We have 9 cisco 3750e switch in stacking 9 stack, recently we are upgrade cisco IOS c3750e-universalk9-mz.150-2.SE10a.bin.
After IOS up-gradation we receive Error-  FRU Power Supply is not responding  please tell me in this case what I do.
Sudhir patil
Rick Morris
Level 6
Level 6
What does your stack power config look like?
Also can you paste in the following:
sh envi all
sh stack-power
jsimons
>config
stack-power stack Powerstack-1
   mode power-shared strict
>sho stack-power det
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
Powerstack-1          SP-PSS  Ring     1400    940     460     0       2    4
Power stack name: Powerstack-1
    Stack mode: Power sharing strict
    Stack topology: Ring
    Switch 1:
        Power budget: 230
        Power allocated: 230
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: Switch 2 - a493.4c37.4580
        Neighbor on port 2: Switch 2 - a493.4c37.4580
    Switch 2:
        Power budget: 230
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: Switch 1 - a44c.11ac.e600
        Neighbor on port 2: Switch 1 - a44c.11ac.e600
>sho stack-power bud
    Power Stack           PS-A   PS-B   Power     Alloc     Avail   Consumd Pwr
SW  Name                  (W)    (W)    Budgt(W)  Power(W)  Pwr(W)  Sys/PoE(W)
1   Powerstack-1          350    350    230       230       0       96   /0
2   Powerstack-1          350    350    230       230       0       88   /0
Totals:                                           460       0       184  /0
>sho stack-power load
    Power Stack           Priority  Consumd  Consumd  Consumd  Alloc  Alloc
SW  Name                  Sw-Hi-Lo  Sw(W)    Hi(W)    Lo(W)    Hi(W)  Lo(W)
1   Powerstack-1           3-12-21  96       0        0        0      0
2   Powerstack-1           4-13-22  88       0        0        0      0
Totals:                             184      0        0        0      0
>sho stack-power neig
    Power Stack           Port 1  Port 1             Port 2  Port 2
SW  Name                  Status  Neighbor SW:MAC    Status  Neighbor SW:MAC
1   Powerstack-1          Conn    2:a493.4c37.4580   Conn    2:a493.4c37.4580
2   Powerstack-1          Conn    1:a44c.11ac.e600   Conn    1:a44c.11ac.e600
>sho env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 26 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     xxxxxxxxxxx OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     xxxxxxxxxxx OK              Good     Good     350/0
2A  C3KX-PWR-350WAC     xxxxxxxxxxx OK              Good     Good     350/0
2B  C3KX-PWR-350WAC     xxxxxxxxxxx OK              Good     Good     350/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
>sho log
Nov 17 17:59:43.623: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
Nov 17 18:01:07.607: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 17 23:30:07.982: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 02:50:04.586: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 06:17:28.179: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 08:14:54.972: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 08:30:53.920: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 10:45:02.668: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 13:49:52.303: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 18 15:15:56.145: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 19 00:25:10.072: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 19 06:49:36.363: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 19 10:47:17.881: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
Nov 19 11:40:48.340: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding (gn4m-rt1p08-04-2)
CiscoPrimeLMS-CiscoView :
tdorsey123
I too suffer this issue with a 2 switch and 4 switch WS-C3750X-48T-S stacks running Universal 15.0(2) SE and IPBaseK9 15.0(2) SE.
Is there a wrong way to create the Ring?
I did:
Switch X port 1 --> Switch X+1 port 2
Last Switch port 1 --> First Switch port 2
Maybe it needs to be:
Switch X port 2 --> Switch X+1 port 1 ?
Last switch port 2 --> first switch port 1 ?
Here is my 4 switch stack power config:
s-core01#sh stack-power det
Powerstack-1          SP-PS   Ring     1400    508     892     0       4    4
    Switch 1:
        Power budget: 223
        Power allocated: 223
        Low port priority value: 19
        High port priority value: 10
        Switch priority value: 1
        Neighbor on port 2: Switch 4 -
    Switch 4:
        Power budget: 223
        Neighbor on port 2: Switch 3 -
    Switch 2:
        Power budget: 223
        Neighbor on port 1: Switch 3 -
    Switch 3:
        Power budget: 223
        Low port priority value: 20
        High port priority value: 11
        Switch priority value: 2
        Neighbor on port 1: Switch 4 -
kyle woodhouse
Hi All,
I was actually getting this error intermitantly as well.  With others seeing it too i figured it was a software bug and was able to find the bug ID and details.  It looks like its fixed in SE2 so i will try that out today.
Hope this helps!
CSCud01798            Bug Details
"FRU Power Supply is not responding" was seen unexpectedly
Symptom:
"FRU Power Supply is not responding" message seen on 3560X/3750X intermittently.
Issue may happen with one or two Power Supply Unit.
Conditions:
3560X/3750X is running IOS 15.0(2)SE.
Workaround:
The power supply is operating normally.
Upgrade to 15.0(2)SE2 or later to resolve this issue.
GNOC
we do have the same issue ... we are using the image " c2960x-universalk9-mz.152-4.E7 " .
Srinivas N
getting error but now it is single switch. "%PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding"
Switch#sh stack-power
Powerstack-1 SP-PS Stndaln 715 492 223 0 1 1
Switch# sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT INITIALIZED
System Temperature Value: 24 Degree Celsius
1A C3KX-PWR-715WAC LIT151302ZA OK Good Good 715/0
1B UNKNOWN unknown No Input Power Bad N/A 0/0
1 Not Present <>
Switch#
Thanks & Regards,
Srinivas.
ujithamail
this might be due to IOS bug. We had the same error with WS-C3750X-12S-E. I found two below bug article of same issue which suggest to upgrade to 15.0(2)SE2 or later to resolve this issue.
Bug article >> CSCud01798
I found these bug article details from this tread too.
source >> https://bst.cloudapps.cisco.com/bugsearch/bug/CSCud01798
