Stacking switches at remote locations
krystian.zajac
I am planning on deployment of 2 cisco switches. They will be located at different floors with the fiber uplink between them. The questions is how can I put them in a stack utilizing the uplinks? I can not use the normal stack cables as the switches are not at the same location.
Thanks for any help!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You can't (I believe), but you can certainly use the fiber uplink interconnections to extend a VLAN (or VLANs if trunking is supported) between two switches.
johuggin
Hello Krystian,
Are you dealing with 3750 switches?
Unfortunately, you cannot have a true stack through fibre uplinks on the 3750s. What you may be looking for is clustering. Here's a doc with more information on clustering on the 3750:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_58_se/configuration/guide/swclus.html
Let me know if you are working with something other than a 3750..
Hope this helps!
Joey
  For ease of management just give them their own management address.
