storm on Cisco 4500 port
cisco11288702
I have Cisco 4500 switch  port Gig22 show 88-99 % usage frequently  port stats  shows its a trunk port all vlan's are allowed i see a lot of Multicast and Broadcast  traffic , My question is how can i tell which Vlan causing  this huge traffic  .
6 Replies 6
Leo Laohoo
If it is a trunk port, what is the switch on the other side? Is it a Catalyst 2k/3k? If it is, what is the exact model and what is the exact IOS version?
its connected to 3750E-universlk9-m   version 15.2(4)E7
Getting this type info from the switch is not easy. If you have a management software like Solarwinds or PRTG, you can monitor each vlans and see the bandwidth  consumption.
Reza
I have solarwinds  but in the same time its trunk port with more than 200 Vlan's , Do you know if solarwinds can tell which Vlan causing this storm.
On the 3750E, enter the command:
sh controllers utilization
NOTE: The output is in "real time".
Deepak Kumar
It is not easy to get details from the switch itself. Better to you Netflow and get top talker and real-time analysis.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
