STP Cost Calculation for Port-Channel (With multiple links)
Alinasirz
Hi Guys,
I see that the port-channel with two fast-Ethernet connections has cost of 12. how is it calculated? what is the formula behind that. Also, what if I need to calculate the cost of 4 or 6 Fa connections in port-channel.
Cisco has never published the formula they use to determine STP costs, but the static values are well documented:
BandwidthOld STP valueNew Long STP value
10 Mbps1002,000,000
100 Mbps19200,000
1 Gbps420,000
N X 1 Gbps310,000
10 Gbps22,000
100 GbpsN/A200
1 TbpsN/A20
10 TbpsN/A2
SpeedResulting Cost
10M100
20M56
30M47
40M41
50M35
60M30
70M26
80M23
100M19
200M12
300M9
400M8
500M7
600M6
700M5
800M5
1G4
2G3
3G3
4G3
5G3
6G3
7G3
8G
Ref: https://community.cisco.com/t5/switching/cost-stp-for-etherchannel/td-p/2401310
Ref: https://community.cisco.com/t5/switching/stp-port-cost-and-etherchannel/td-p/2795286
Please remember to vote and mark correct answer if this answers your question!
-Zac
I do not remember whether I saw a formula to calculate STP costs. However, whenever you add members to Port-channels, you will lower the cost. If you do not want the STP cost to change, you will need to configure STP cost using "spanning-tree cost X".
You can reference in the following link:- https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/l2/spanning-tree-cost.html
HTH,
Meheretab
HTH,
Meheretab
Martin L
based on speed of link. you need to find table with stp costs listed.
not much info but some short and long cost values are listed
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/24330-185.html
maybe somewhere on this page cost is shown
https://www.cisco.com/c/en/us/tech/lan-switching/spanning-tree-protocol/index.html
but likely you would have to go to IEEE site and look up the standard
10 Mbps1002,000,000
100 Mbps19200,000
1 Gbps420,000
N X 1 Gbps310,000
10 Gbps22,000
100 GbpsN/A200
1 TbpsN/A20
10 TbpsN/A2
SpeedResulting Cost
10M100
20M56
30M47
40M41
50M35
60M30
70M26
80M23
100M19
200M12
300M9
400M8
500M7
600M6
700M5
800M5
1G4
2G3
3G3
4G3
5G3
6G3
7G3
8G
-Zac
